I need to replace the hinges and the receptors on both doors. The parts listings show 2 different hinges and 2 different receptors. How do I know which part is correct? Thanks. Model is JJW9630DDB. Ron
Originally Posted by: Ron6519 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I need to replace the hinges and the receptors on both doors. The parts listings show 2 different hinges and 2 different receptors. How do I know which part is correct? Thanks. Model is JJW9630DDB. Ron Ron the series number ( the first 2 numbers of the serial number)will determine which part to order/replace. If you can re post the model and the serial number, we'd be happy to do the research the parts for you. :) :) :)
Thanks. I'll have to get to it after the oven is off. Ron
Originally Posted by: Ron6519 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks. I'll have to get to it after the oven is off. Ron Ron, Not a problem, We'll keep an eye out for your next post. :) :) :)
Joe, this just gets better. I made out the first 3 characters as "115" and the rest were grease covered. I took a sponge with soap to clean off the grease and it wiped out the serial number completely. Is there another place the serial # would be? I bought the ovens in about 2004. Ron
Originally Posted by: Ron6519 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe, this just gets better. I made out the first 3 characters as "115" and the rest were grease covered. I took a sponge with soap to clean off the grease and it wiped out the serial number completely. Is there another place the serial # would be? I bought the ovens in about 2004. Ron Ron, Sorry, but no, there is not a hidden model/serial tag. So at this point you have a J/A double wall oven, model number JJW9630ddb series 11. (you may want to keep that handy for future reference. With that, you will need to order at least one hinge/receptacle kit( you have the same hinges/receptacle on both doors), Part number: AP4009190
After you install the kit, put the oven in a 4 hour self clean cycle, you'll be a lot more happy with the results. Good Luck, :) :) :)
Joe, a couple of more questions. Does the kit contain 2 hinges and 2 receivers. Enough to do one door? AND Are these kits an upgraded set of hardware, as the original set was not up to the task of holding the doors shut. I don't want another under engineered hinge set. Thanks. Ron
Originally Posted by: Ron6519 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe, a couple of more questions. Does the kit contain 2 hinges and 2 receivers. Enough to do one door? AND Are these kits an upgraded set of hardware, as the original set was not up to the task of holding the doors shut. I don't want another under engineered hinge set. Thanks. Ron Ron, Yes on both counts, the hinges and receivers are re-engineered for longevity and a more "positive" closing action. The "kit" will contain everything you need to repair 1(one) door assembly. The 4 hour self clean cycle, has been a "unwritten" rule of thumb, on J/A products for 30 + years, that I know of. You'll be fine, Good Luck, :) :) :)
Thanks for the information. Ron
Originally Posted by: Ron6519 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks for the information. Ron Ron, You're welcome, You'll do fine. :cool: :cool: :cool:
