AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Microwave makes srange noise and emits burning odor
Microwave runs but makes odd noise and emits burning odor. Not sure if it is heating properly. I dont want to run it because of the burning smell
Thats the best way of finding out whats causing the smell is run it and watch which componant is smoking you wont hurt nothing that isn't already trashed a transformer or a diode with produce odors a mag usually wont for very long and a capacitor will trip breakers
I tried to heat a glass of water for two minutes. Microwave does not heat, still emits plastic burning odor and makes strange noise while running
open the control panel check the diode and transformer
how do I open the control panel. Do I have to take the microwave out of the cabinetry
GE usually has 2-3 screws going into the side of it where the door closes against it .... that side then it will lift up and down
What am I looking for as I have located the diode and transformer
Microwave Repair
