kelly123
#1 Posted : Saturday, November 15, 2008 10:47:54 PM(UTC)
kelly123
This microwave was recently recalled for a problem involving the door switches overheating causing internal plastic parts possibly burn and cause a fire. :eek:
Does anyone know what part or parts need to be replaced to fix this problem. :confused:
#2 Posted : Sunday, November 16, 2008 6:02:06 PM(UTC)
If it was recalled then you have to call GE to fix it. You can find the complete information regarding this recall here.
kelly123
#3 Posted : Sunday, November 16, 2008 8:22:20 PM(UTC)
kelly123
Hi Gene,
Thanks for your reply. The Combo unit was replaced and the people are using the conventional oven part of the old one. If I knew which parts needed I could make it safe to use the microwave part.
Kelly
v2k04
#4 Posted : Sunday, November 16, 2008 8:57:35 PM(UTC)
v2k04
All it consists of is an interlock module for the door latch about a 10 min. repair just order the interlock for the unit The ordered part will be the updated one
kelly123
#5 Posted : Sunday, November 16, 2008 9:24:07 PM(UTC)
kelly123
Thanks V,
Would you have a part no. so I could order this interlock module from APP or whoever?
Thanks again, Kelly
v2k04
#6 Posted : Monday, November 17, 2008 6:12:09 AM(UTC)
v2k04
Oder here from this site
Latch body
Part Number: Part number: AP4315609
made by GE
Switch - monitor
Part Number: Part number: AP2024338
made by GE
Switch, door sense
Part Number: Part number: AP2024337
made by GE(2)
hlm760
#7 Posted : Sunday, January 25, 2009 7:48:13 PM(UTC)
hlm760
I don't think my unit is part of the recall, but yesterday I started having issues with the microwave. I can turn it on to reheat food, but it doesn't heat. I also smell a slight electrical burning smell, but no smoke or wierd nosies. Any ideas? My novice guess is that it has a burnt fuse, but not sure of much else.:confused:
kelly123
#8 Posted : Monday, January 26, 2009 10:34:57 AM(UTC)
kelly123
Check the door interlock switches - especially the top switch. If you see a scorched wire connection on that switch, that's probably the problem. The switch will need to be replaced. I'm not an expert, but I've seen this on 2 GE microwave units. Hope this is helpful.
Mr. Timewise
#9 Posted : Friday, March 27, 2009 7:34:36 PM(UTC)
Mr. Timewise
To all owners of the SCA2001BSS03:
I found the Technical Data Sheet with the wiring diagram behind the control panel along the inside wall. The paper was in an envelope glued to the right side vertical wall.
