Forastiero
#1 Posted : Wednesday, November 5, 2008 7:49:42 AM(UTC)
Forastiero
Need to make sure how to remove this panel from my freezer door so I don't break it in the process. Do I just pry along the top side, or is there a better way? Thanks! The control panel is a WR55X10001. Pictures are attached.
File Attachment(s):
Refrigerator Door.doc (1,355kb) downloaded 10 time(s).
abadfish66
#2 Posted : Wednesday, November 5, 2008 8:35:30 AM(UTC)
abadfish66
It pops right off, get a putty knife or something thin and work it up through the bottom, you'll see once you look up at it from the bottom.
Forastiero
#3 Posted : Wednesday, November 5, 2008 9:41:07 AM(UTC)
Forastiero
It came right out. I wanted to pull the board to check for a possible poor connection causing a persistant "dE" indication. That must have been the case since it is now working fine!! Thanks for the help.
abadfish66
#4 Posted : Wednesday, November 5, 2008 9:45:19 AM(UTC)
abadfish66
If it comes back, your gonna want to check the defrost system, as that is usually why the DE pops up
Forastiero
#5 Posted : Thursday, November 6, 2008 3:14:40 AM(UTC)
Forastiero
You're probably right. When I unplugged the board I probably reset it and I expect the "dE" will show up again after 64 hours. If so I will attack the defrost circuit. Thanks
Forastiero
#6 Posted : Saturday, November 8, 2008 10:06:13 AM(UTC)
Forastiero
Your were right. The "dE" showed up again, so I traced the problem to the defrost heater and thermostat (yes both!). I just ordered a replacement (both come together w/harness)from you guys with expedited shipment. That should do it. Thanks again for you help.
abadfish66
#7 Posted: : Saturday, November 8, 2008 10:50:29 AM(UTC)
abadfish66
Good, let us know
Forastiero
#8 Posted : Sunday, November 9, 2008 4:35:59 AM(UTC)
Forastiero
Another question - What is the best way to tighten up on the freezer door handle. It is only slightly loose, but since the unit is "down for repair" I thought it would be a good time to do this also. Thanks
Forastiero
#9 Posted : Saturday, November 15, 2008 2:37:55 PM(UTC)
Forastiero
As a follow, replacing the defective defrost element corrected the problem. The defrost thermostat was not defective as I stated earlier (it is normally open at room temp). Thanks for the help
LG LFXS28968S /00 control panel removal (Refrigerator & Freezer Repair)
by Guest 11/15/2023 5:36:56 PM(UTC)
control panel removal (Washer Repair)
by jwdyer2445 7/30/2012 10:17:57 PM(UTC)
Kitchenaid KSRG25FKSS16 Ice dispenser control panel removal (Refrigerator & Freezer Repair)
by gbooth 12/29/2011 3:14:20 PM(UTC)
control panel removal (Dryer Repair)
by Pauly H 10/25/2010 7:21:04 AM(UTC)
whirlpool double oven control panel removal (Oven Repair (including Ranges and Cooktops))
by Glrbird 5/5/2010 11:07:44 AM(UTC)
Keypad / control panel removal & replacement (Oven Repair (including Ranges and Cooktops))
by Fireweed 8/26/2009 7:53:57 AM(UTC)
DMO24 Control Panel Removal (Microwave Repair)
by reh 3/20/2009 5:25:26 AM(UTC)
Electric oven control panel removal (Oven Repair (including Ranges and Cooktops))
by stpedson 3/14/2009 9:11:46 AM(UTC)
Control Panel Removal (Refrigerator & Freezer Repair)
by Sonettech 11/16/2008 8:03:02 PM(UTC)
by bjthedj 10/27/2008 8:11:51 AM(UTC)
Control Panel Removal (Dishwasher Repair)
by PeteME 9/27/2007 10:01:48 AM(UTC)
