ChiefWen
#1 Posted : Monday, October 27, 2008 7:19:26 AM(UTC)
ChiefWen
911.41485890 The mircowave part is not spinning and not heating up. Is it a belt that needs replaced or a part? Any ideas? Thanks.
#2 Posted : Monday, October 27, 2008 2:23:55 PM(UTC)
The first thing I would check is the secondary interlock switch (on the door frame). With the door closed the switch should be closed.
- The part number for the switch is AP2024337
ChiefWen
#3 Posted : Monday, October 27, 2008 2:52:04 PM(UTC)
ChiefWen
It appears that everything is working but the turntable and heat. Your recommending to replace this piece completely? Once this is replaced, it should work? I want to make sure I understand. Thanks.
#4 Posted : Monday, October 27, 2008 2:58:04 PM(UTC)
I did not recommend to replace it. I did recommend to check it and replace only if it's bad. You have to check it for continuity.
ChiefWen
#5 Posted : Monday, October 27, 2008 4:11:33 PM(UTC)
ChiefWen
That part appears to be bad. I've ordered the part and will see if thats the problem. Thanks for your help.
#6 Posted : Monday, October 27, 2008 4:59:51 PM(UTC)
Keep us posted.
ChiefWen
#7 Posted : Thursday, October 30, 2008 12:55:30 PM(UTC)
ChiefWen
That was not it. Any other ideas?
abadfish66
#8 Posted : Thursday, October 30, 2008 1:48:57 PM(UTC)
abadfish66
A bad monitor switch will cause this to happen.
ChiefWen
#9 Posted : Tuesday, November 4, 2008 12:34:33 PM(UTC)
ChiefWen
That wasn't it. Any other ideas?
