emb04
#1 Posted : Monday, April 18, 2011 6:02:13 AM(UTC)
emb04
My oven (Whirlpool RF378PXG Q1) recently stopped working. The stove top works fine.
The oven itself was working great too then one day ... nothing. Neither element seems to work.
There are NO codes showing in the electronic display. When looking at the display, it appears as if everything is working fine. It shows the oven preheating... does the countdown .. the timer works.. everything.. except the oven will not heat up.
My guess is it is the thermal fuse or maybe the elements, but since both elements stopped "working" at the same time I think that would be a HUGE coincidence.
Any ideas??? :confused:
#2 Posted : Monday, April 18, 2011 6:37:01 AM(UTC)
Replacement parts for WHIRLPOOL RF378PXGQ1 ELECTRIC FREESTANDING RANGE | AppliancePartsPros.com
It does not look like it has a thermal cut-off.
I would unplug the unit and remove the back to check for a burned out wire.
I am assuming you tried it on broil and that also did not work.
Unfortunately I would put the control board at the top of the list.
File Attachment(s):
RF378.pdf (197kb) downloaded 6 time(s).
Oven will not work (Oven Repair (including Ranges and Cooktops))
by Marine2054 3/28/2015 2:35:41 PM(UTC)
Whirlpool Flat Top Stove AND Oven will not work (Oven Repair (including Ranges and Cooktops))
by sonia0865 11/19/2014 6:34:40 AM(UTC)
Heating elements/oven will not work (Oven Repair (including Ranges and Cooktops))
by bobcraycraft 9/15/2013 5:23:18 AM(UTC)
my magic chef range oven will not work (Oven Repair (including Ranges and Cooktops))
by dclary 3/10/2013 11:38:27 PM(UTC)
by rough 7/8/2012 4:43:21 AM(UTC)
Upper Oven will not work. (Oven Repair (including Ranges and Cooktops))
by Dan1612 4/24/2012 3:16:13 PM(UTC)
by JohnWiggs 3/10/2011 11:46:16 AM(UTC)
Oven will not work (does not get hot) (Oven Repair (including Ranges and Cooktops))
by newportprof 10/4/2010 9:52:22 AM(UTC)
by Ameryl 12/11/2009 4:59:57 PM(UTC)
Oven will not work period (Oven Repair (including Ranges and Cooktops))
by steakmast3r 8/31/2009 7:32:20 PM(UTC)
by brucewill 6/11/2009 9:11:14 AM(UTC)
Whirpool oven will not work, cooktop works fine (Oven Repair (including Ranges and Cooktops))
by LRN4569 11/17/2008 6:56:45 AM(UTC)
Oven Will Not Work (Oven Repair (including Ranges and Cooktops))
by edturner 10/21/2008 8:36:23 AM(UTC)
Oven will not work when humid outside (Oven Repair (including Ranges and Cooktops))
by DavidJosie 9/13/2008 6:51:14 PM(UTC)
by kal 7/22/2008 2:20:39 PM(UTC)
