Dr-Greg
#1 Posted : Friday, April 8, 2011 1:12:05 AM(UTC)
Dr-Greg
I just bought a new home and it has a KitchenAid cooktop/oven combo model KESI901PBL00 - here are the problems that need solved:
1. The lower-right burner's glass is scratched to the point where a small chunk of the Schott Ceran glass is gone (about the size of a penny) And there are several other smaller dents. I'm guessing the whole glass top needs replaced?
2. The same lower-right burner does not heat up to its full potential. Does that mean the burner needs replaced too? I could not tell which of the burners available applied to this lower-right burner - they are all different wattages and I would need to know exactly which one is needed.
Thank you.
#2 Posted : Friday, April 8, 2011 1:46:02 AM(UTC)
Replacement parts for WHIRLPOOL KESI901PBL00 30" SLIDE-IN ELECTRIC OVEN | AppliancePartsPros.com
If you do not have the operators nmanual it can be downloaded from the Whirlpool site "Owner Center" use KESI01 to find it.
[COLOR="DarkRed"]I'm guessing the whole glass top needs replaced?[/COLOR]
Yes.
Looks like all are out of stock which often translates to obsolete so you will have to call them.
[COLOR="DarkRed"]
The same lower-right burner does not heat up to its full potential. Does that mean the burner needs replaced too? [/COLOR]
Looking at the wiring diagram it should be a 1800 watt single element but I am not 100% sure on this. The people at AppliancePartsPros will know.
You will see that it has a simmer switch so I would check that also odds are low heat could be the infinite control switch.
Elements usually either burn out or work.
File Attachment(s):
KESI901.pdf (469kb) downloaded 6 time(s).
Dr-Greg
#3 Posted : Friday, April 8, 2011 10:41:39 AM(UTC)
Dr-Greg
Thank you very much for the info. Yeah, AppliancePartsPros seems to not carry the cooktop in stock but Sears parts says they have it.
Regarding the lower-right burner, you were right. My simmer switch was flipped to the ON position. I haven't tried it out yet since flipping it back, but do you think this fixed the problem? I've never had a cooktop with a simmer switch before so I wasn't sure what it did exactly or which burner it applied to.
If thats the case then all I need to do is order a new glass cooktop and I'm set.
#4 Posted : Saturday, April 9, 2011 3:12:25 AM(UTC)
[COLOR="DarkRed"]I haven't tried it out yet since flipping it back, but do you think this fixed the problem?[/COLOR]
My guess would be yes but that is just a guess.
Only testing it will tell.
Guest (5)
Kitchenaid cooktop - combo burner only works as big (Oven Repair (including Ranges and Cooktops))
by beb123 9/2/2013 5:37:44 PM(UTC)
KitchenAid Cooktop—bottom right burner doesn't heat up (Oven Repair (including Ranges and Cooktops))
by szbz 10/16/2011 1:49:40 PM(UTC)
Replace spark module on Kitchenaid cooktop (Oven Repair (including Ranges and Cooktops))
by alenhoff 12/14/2010 4:12:26 PM(UTC)
Kitchenaid Cooktop problems (Oven Repair (including Ranges and Cooktops))
by kpendlet 4/27/2010 5:15:38 PM(UTC)
kitchenaid cooktop won't lite (Oven Repair (including Ranges and Cooktops))
by ehut1 9/23/2009 12:54:29 PM(UTC)
Parts for a Kitchenaid cooktop (Oven Repair (including Ranges and Cooktops))
by hht 8/3/2009 12:51:22 PM(UTC)
KitchenAid Cooktop Gas Comes out slow at start (Oven Repair (including Ranges and Cooktops))
by dgade89 12/29/2008 11:42:37 PM(UTC)
Kitchenaid cooktop spark intermittant (Oven Repair (including Ranges and Cooktops))
by Rich C 12/23/2008 8:40:34 PM(UTC)
KitchenAid cooktop won't spark (Oven Repair (including Ranges and Cooktops))
by nimsu71 6/10/2008 1:13:23 PM(UTC)
Kitchenaid Cooktop (Oven Repair (including Ranges and Cooktops))
by kc135guy 5/10/2008 2:24:27 PM(UTC)
kitchenaid cooktop gasket (Oven Repair (including Ranges and Cooktops))
by mark31904 4/25/2008 6:17:34 AM(UTC)
kitchenaid cooktop won't shut off (Oven Repair (including Ranges and Cooktops))
by jappel2 3/20/2008 6:06:28 AM(UTC)
