szbz
#1 Posted : Sunday, October 16, 2011 1:49:40 PM(UTC)
szbz
I have a 6-year-old Kitchen Aid electric cooktop. Exactly one year ago, when top was damaged, glass range top was replaced and it has worked perfectly since then. Control dial for this burner lites up and appears fine but one day, suddenly this one burner doesn't get hot. It was expensive replacing the entire top. Is there someone that can tell me how to trouble-shoot to see if there are particular small part(s) that could be replaced rather than replace the entire glass top? Thank you.
#2 Posted : Monday, October 17, 2011 1:35:41 AM(UTC)
Replacement parts for WHIRLPOOL KECC508RPB00 30" ELECTRIC BUILT-IN CERAN COOKTOP | AppliancePartsPros.com
Here is a manual
http://appliancedigest.c...l-cooktop-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
You will not have to replace the entire cooktop.
Remove the element and check it with a meter.
If OK then odds are that the control board is shot (Item 15) if the stove top control seems to function properly.
Be sure to remove power from the unit when working on it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
KECC508.pdf (134kb) downloaded 8 time(s).
szbz
#3 Posted : Monday, October 17, 2011 10:40:41 AM(UTC)
szbz
I've been unable to download service manual for KECC508RPB00. Please help me do this. I have joined ApplianceDigest.com but when I go there to get manual it just throws me back to AppliancePartsPros web site. (I'm using a MacIntosh with Safari browser. Is that a problem?)
Also, does the part #15 you recommended (control board) come attached to ceramic cooktop if I opted to replace the whole ceramic top. Since ceramic top went out 6 days after warranty was up I was offered a discount on a new top and the new top is not much more than part #15. So, if I bought the new top, would it come with part #15?
You said to remove the "element". Please explain. Is this a round electronic unit separately attached to the ceramic cooktop? Does it come off?
#4 Posted : Monday, October 17, 2011 12:35:41 PM(UTC)
Cooktop will not include part #15
Go to the site and sign in.
Then go to Downloads
Then Cooking Products
Then Page 3
Then Whirlpool KAC-23
