justjim2
#1 Posted : Thursday, October 23, 2008 4:47:57 PM(UTC)
justjim2
When I press the control pad to turn on the bake cycle, it will not function. When I press the broiler pad button, the broiler works fine. When I press the pad for "clean" the broiler unit turns on, but the bake unit does not. My question is, "will the bake touch pad not function (make it's beep noise) if the bake element is burnt out?" The oven was purchased in January 2002 and has been used a lot.
#2 Posted : Friday, October 24, 2008 1:55:56 PM(UTC)
Most likely the problem is a bad Bake pad. Unfortunately the membrane switch for this model is no longer available.
justjim2
#3 Posted : Saturday, October 25, 2008 12:39:43 PM(UTC)
justjim2
Thanks Gene.
By a "bad bake pad" you mean the heating element, correct?
#4 Posted : Monday, October 27, 2008 7:11:05 PM(UTC)
Well, lets start it over. What was shown on the display when you pushed the Bake button on the control panel? What happened to the Bake igniter at that time?
