gregoz
#1 Posted : Monday, March 28, 2011 2:21:38 PM(UTC)
gregoz
My wife went to use our oven today, and in the middle of her baking, the code F2 showed up on the display, and the store started beeping. Unplug the stove, let it cool off, and plug it back in, and the F2/beeping starts all over again.
Any suggestion on what could be causing this and where I could test / part(s) to buy to replace to get the stove back in operation??
TIA,
Greg
gregoz
#2 Posted : Tuesday, March 29, 2011 10:17:53 AM(UTC)
gregoz
TIA,
Greg
So after unplugging/plugging the unit in after it had cooled off, and getting the same F2 code, tried sliding the oven's lock latch back and forth a few times, leaving it slid all the way to the left. Now, plug back in the unit to the wall, and it powers on and no more F2 code. :)
gregoz
#3 Posted : Tuesday, March 29, 2011 11:01:51 AM(UTC)
gregoz
Back to square one... After being plugged in for about 20 minutes w/no beeping/F2 code, the range on its own started beeping and flashing F2 again. All the burners, and the stove have been off the entire time. :mad: Suggestions appreciated...
#4 Posted : Tuesday, March 29, 2011 3:59:54 PM(UTC)
Sounds like the problem is a bad control board aka an Electronic Range Control.
- The ERC Part number: AP2633044
gregoz
#5 Posted : Tuesday, March 29, 2011 4:24:01 PM(UTC)
gregoz
Gene-
Thanks for the advise, I agree. I've taken the unit out, and found 2 bad (arc'ed) relays
Thanks,
Greg
#6 Posted : Tuesday, March 29, 2011 6:00:01 PM(UTC)
You are welcome Greg. Keep us posted.
