alan2275lor
#1 Posted : Friday, October 3, 2008 4:30:13 AM(UTC)
alan2275lor
Could anyone tell or show me photo where the thermal fuse and ignitor located for Frigidaire gas dryer?
#2 Posted : Friday, October 3, 2008 4:59:29 PM(UTC)
We need the complete model number of the dryer. You can find it on the door frame or on the top panel.
alan2275lor
#3 Posted : Wednesday, October 8, 2008 7:39:55 AM(UTC)
alan2275lor
Hi Gene,
I have Frigidaire dryer model: FDG37GHS0. COULD YOU TELL ME HOW TO CHECK THERMOSTAT, TIMER, TEMP SELECT SWITCH, SENSOR, IGNITOR IN RESISTANCE. I OPEN THE DRYER APART, BUT DON'T KNOW HOW TO CHECK OR MEASURE THE DEVICES. I MEASURED ON IGNOTOR WITH 62 OHM, IS IT SUPPOSE TO BE THE SPECIFICATION? ALSO MEASURE TEMP SELECT SWITCH: HIGH TEMP SELECT WITH 7k OHM, MID TEMP WITH1.8k OHM, AND LOW TEMP WITH ZERO OHM. ARE THESE READING CORRECT? According to diagram: at high temp selection it should be open, at mid temp - it should be 2.4K ohm, and at low temp - it should be max of 10 ohm.
I SEE THE IGNITOR LIGHT UP FOR SECOND AND CUT OFF, AND THERE IS NO HEAT.
PLEASE HELP.
#4 Posted : Wednesday, October 8, 2008 9:07:37 AM(UTC)
Originally Posted by: alan2275lor Go to Quoted Post
...I SEE THE IGNITOR LIGHT UP FOR SECOND AND CUT OFF, AND THERE IS NO HEAT...
The first failure suspect are the gas valve coils.
- The part number for the set of coils is AP2150379
alan2275lor
#5 Posted : Wednesday, October 8, 2008 9:32:21 AM(UTC)
alan2275lor
Hi Gene,
Is there any possible way to check to see if the gas valve coils good or bad? can it be measured with DMM?
#6 Posted : Wednesday, October 8, 2008 9:47:19 AM(UTC)
The coil with two terminals should have 1220 ± 50 Ohms.
The coil with three terminals, if held with terminals in upper position:
a). across the left and the middle terminals - 1365 ± 25 Ohms
b). across the right and the left terminals - 560 ± 25 Ohms.
alan2275lor
#7 Posted : Wednesday, October 8, 2008 10:53:12 AM(UTC)
alan2275lor
Gene,
what about thermostat heat control, sensor,and ignitor? I want to make sure these aparts measure fine before replace them.
And what about temp selection switch?
:D
#8 Posted : Wednesday, October 8, 2008 11:01:08 AM(UTC)
I do not think there is something wrong with these parts. I would start with the gas valve coils unless you want to replace everything. Don't make it more complicated than it is.
alan2275lor
#9 Posted : Friday, October 10, 2008 6:28:07 AM(UTC)
alan2275lor
Hi Gene,
Your support was helpful, I found my secondary coil burn. I replaced the part and now my dryer is backed to normal operation. My wife is happy and thanks for your great job.
:p :p :p :p :p
#10 Posted : Friday, October 10, 2008 5:01:32 PM(UTC)
You're welcome. I'm glad you were able to fix it and a happy wife is most important.
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
2012 GE Frigidaire gas dryer PN FAQG7111LW (Dryer Repair)
by paultclem 4/1/2019 7:36:22 PM(UTC)
Frigidaire gas dryer no heat (Dryer Repair)
by mbarone 3/18/2012 4:25:38 PM(UTC)
Intermittent heat Frigidaire Gas Dryer (Dryer Repair)
by pvanv 7/2/2011 7:55:59 AM(UTC)
by snobgnol 1/24/2011 10:06:02 AM(UTC)
Frigidaire gas dryer stops igniting (Dryer Repair)
by kbtl4 10/14/2010 11:13:25 AM(UTC)
Frigidaire Gas Dryer No Heat (Dryer Repair)
by mtsolutions 5/15/2010 3:18:57 PM(UTC)
Frigidaire Gas Dryer Tumbling but not drying (Dryer Repair)
by djneil1 7/21/2009 10:33:12 AM(UTC)
How to access igniter? - Frigidaire gas dryer (Dryer Repair)
by andrew99 3/17/2009 3:30:48 PM(UTC)
Frigidaire Gas Dryer - heat inconsistent (Dryer Repair)
by futbol79 4/14/2008 7:55:28 AM(UTC)
Frigidaire Gas Dryer works but No Heat, Why?? (Dryer Repair)
by mvetri 11/2/2007 1:28:35 PM(UTC)
