KLee
#1 Posted : Monday, February 28, 2011 10:53:03 AM(UTC)
KLee
Hello:
The Way of Drum Installed (Suspended Method)
The drum of this washer is NOT fixed to the frame but being supported by four shock absorbers and suspended by two springs.
Observations
Upon two observations that (1) noise during spinning and (2) a tilted drum backward (visible recognition) as oppose to be parallel with the floor, I would like to ask you whether the main problem is caused by the malfunctioning of shock absorber and/or spring.
Appreciation for Your Help
If you think it could be the case, I would appreciate you for the detail instruction to replace the shock absorber and the springs.
Thank you. Kun
Jeff / APP Team
#2 Posted : Tuesday, March 1, 2011 7:02:47 AM(UTC)
Jeff / APP Team
The tub on these are suppose to lean to the back. What kind of noise are you getting? Where does it sound like it's coming from? Thanks.
