gtl545
#1 Posted : Monday, February 21, 2011 9:03:37 AM(UTC)
gtl545
There is play in the blade where it connects to the motor, while spining this play enables the blade to bang against the motor housing. Is there a
way to tighten the blade to eliminate the play?
Jeff / APP Team
#2 Posted : Monday, February 21, 2011 9:20:47 AM(UTC)
Jeff / APP Team
Uninstall the fan motor. There should be a nut on the front of it. Hold the fan blade to keep the shaft from turning. Tighten nut. Should fix your problem. Hope this helps.:)
gtl545
#3 Posted : Monday, February 21, 2011 9:30:58 AM(UTC)
gtl545
Thank you. Is the nut on the inside of the motor assembly? There isn't one on the post coming out of the housing. There is a flat metal part holing the blade onthe the motor, but I couldn't fiure out a way to tighten...
Jeff / APP Team
#4 Posted : Monday, February 21, 2011 9:33:46 AM(UTC)
Jeff / APP Team
That is the nut. You will have to use needle nose pliers for this. I will put a picture of the motor and nut on here for you to see if yours looks like this.Part number: AP2111368
gtl545
#5 Posted : Monday, February 21, 2011 9:46:27 AM(UTC)
gtl545
Yes that looks like it. I will try your suggestion...
Thanks much!!
Jeff / APP Team
#6 Posted : Monday, February 21, 2011 9:49:49 AM(UTC)
Jeff / APP Team
Your welcome! Glad we could help!
