jackd3
#1 Posted : Saturday, October 6, 2007 5:06:10 AM(UTC)
jackd3
When my dryer starts up the heat comes on. After less than a minute the heat shuts off. I have checked all the venting, everything is clear. What could be causing the heat to shut off?
Pegi
#2 Posted : Saturday, October 6, 2007 7:11:36 AM(UTC)
Pegi
Does it relight every time after it shuts off? If so sounds like something is causing the burner to shut off on the hi-limit safety, see if the flame is lifting up tripping this safety thermostat...blocked air flow can cause this or a draft coming in from the dryer vent....can be other causes but check this first...
jackd3
#3 Posted : Saturday, October 6, 2007 11:32:29 AM(UTC)
jackd3
No it will not relight after it goes out. If I open the door, wait about a minute and restart, it will reignite and then shut off again.
No dryer heat (Dryer Repair)
by adamson 8/9/2009 3:11:05 PM(UTC)
No Dryer Heat/No shut of in auto cycle (Dryer Repair)
by fred2117 4/30/2009 2:09:57 AM(UTC)
No Dryer Heat (Dryer Repair)
by Warren 8/7/2007 10:34:27 AM(UTC)
