sehanks
#1 Posted : Thursday, February 10, 2011 8:46:26 AM(UTC)
sehanks
I'm trying to replace the outer tub on a Maytag 3000 front-load washer (MHWE300VF00), but I can't get the basket to separate from the outer tub. Can someone please tell me how to separate the outer tub from the basket?
Thank you!
Repair Technician
#2 Posted : Thursday, February 10, 2011 10:44:32 AM(UTC)
Repair Technician
Hello,
If you have the tubs split and the inner tub will not pull free from the bearing you may want to try a rubber mallet and block of wood.
Set the piece of wood on the top of the spin basket shaft, give it a tap and tub should pull free.
Appliance Repair Technician:
sehanks
#3 Posted : Thursday, February 10, 2011 12:44:25 PM(UTC)
sehanks
Thank you for replying. I already tried to knock it out as you suggested. I started out tapping it gently and worked my way up to hitting it so hard that I split several 2x4s. It won't budge.
Is there nothing that holds it in?
gfee
#4 Posted : Saturday, October 31, 2015 8:56:04 AM(UTC)
gfee
Not sure if Im in the right spot here, but trying to get some assistance on replacing the bearings on this unit, sounds like a jet taking off while in drain or spin mode. tube is not rubbing, no plastic in and around tub, but real noisy during the cycles mentioned. First, am I in the right diagnose mode here and is it relatively easy to replace bearings? tks for any assistance, greg
