Originally Posted by: Ludwig ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif)
The ice water dispenser quit dispensing. There seems to be a switch that is activated when you push against the padded bracket with a glass. Is there a pump? How does this all work?
I also cannot figure out how to remove the cover and/or cover insert so I can look at the inner workings. How do I remove them? What is the recommended diagnosis and/or repair?
Ludwig,
It's not that elaborate a system,
When you press the water dispenser paddle, or the icemaker calls for water to fill the mold, the system activates the solenoid(s) on the fill valve(on the back of the refrigerator),
The fill valve opens and allows water in.
The icemaker has a preset fill time, and allows only so much water to enter the ice maker.
The water dispenser works slightly differently, when the valve opens, the water is released, goes through the filter, then to the water tank, from the tank to the dispenser. If things are working properly, it will dispense water as long as you hold the paddle in.
Now,
Do you hear a switch"click" noise when you press the paddle, and the same when you release it ?
To access the internal components of the dispenser assembly,
***First turn power off or unplug the power cord.***
On the bottom edge of the dispenser facia, you will see two slots molded into the plastic edge.
With a flat blade screwdriver, and a pad of some sort to protect the door panel(some people use the drip grille) pry out or twist the screwdriver, until the bottom of the panel "unsnaps", then carefully push up on the panel, to unhook the tabs from the dispenser housing, and disconnect any harness between the touch pad and control board.
You now have access to the switch mounting bracket assembly,
Remove the two screws that hold the switch bracket to the dispenser housing and carefully move the assembly out to access the switches,and wiring.
Good Luck,
