calvert41
#1 Posted : Tuesday, September 16, 2008 5:25:31 AM(UTC)
calvert41
Have a GE Advantium 120 and the turntable stopped turning. Have checked for debri, all is clear but still will not turn. Help in any way with this issue would be GREATLY APPRECIATED
#2 Posted : Tuesday, September 16, 2008 3:03:11 PM(UTC)
Remove the bottom cover. Remove the wires from the motor (#1472 on the break down diagram) and check for 120VAC to the motor while the microwave is "on".
If there is 120VAC then replace the motor.
If there is no 120VAC then replace the control board.
- The part number for the turntable motor assembly is AP3183636
- The part number for the control board is AP3186997
Here are the break down diagrams for the GE microwave Model SCA1001FSS001
calvert41
#3 Posted : Tuesday, September 16, 2008 3:31:37 PM(UTC)
calvert41
:) Gene THANK YOU so much for your advise and expertise to steer me in the right direction
#4 Posted : Tuesday, September 16, 2008 3:44:10 PM(UTC)
You're welcome. Keep us posted.
calvert41
#5 Posted : Tuesday, September 16, 2008 4:26:18 PM(UTC)
calvert41
:) I sure will
Thanks again
calvert41
#6 Posted : Monday, September 29, 2008 5:25:13 AM(UTC)
calvert41
I replaced turntable motor and it WORKS, she is happy.
Can't thank you enough.
Thanks,
Mark
calvert41
#7 Posted : Thursday, October 16, 2008 11:33:02 PM(UTC)
calvert41
Gene thanks a million. Replaced motor and it works.You made it so easy, especially by supplying the part #'s.
#8 Posted : Friday, October 17, 2008 3:01:32 PM(UTC)
Spacemaker XL1800 turntable not turning (Microwave Repair)
by sedquid 12/24/2011 6:10:33 PM(UTC)
Microwave turntable not turning (Microwave Repair)
by richard Keller 4/26/2011 8:32:50 AM(UTC)
by raggediean 1/8/2011 1:56:57 PM(UTC)
Jenn air turntable not turning (Microwave Repair)
by Rharvey742 3/2/2010 5:37:12 AM(UTC)
Turntable not turning (Microwave Repair)
by dongre 2/18/2010 3:55:32 PM(UTC)
Brand new Microwave Turntable not turning (Microwave Repair)
by trimbojd 5/2/2009 12:24:45 AM(UTC)
GE Spacemaker turntable not turning (Microwave Repair)
by kukadyga 10/16/2008 5:56:53 PM(UTC)
