Originally Posted by: mqcheng64 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Maytag MDG8600AWW Dryer Sounds like the problem is a bad gas valve itself. - The gas valve Part number: AP4037259
Got a gas dryer Whirlpool model SGDX600JQ2, the timer is not turning, heat will kick in for about 5 minutes, then the heat will shut off, the dryer will keep on turning all day if a do not shut it off manually. I need advise an what to part to buy. Matt
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Gene, I will order the parts to install, and keep you posted on the outcome. Thx for your quick response. Matt ;)
Hi Gene, This is Mqcheng64 , I received the Gas Valve today from APP. and installed it, it's works few times and goes back same problem. what do i do next?Thanks
Originally Posted by: mqcheng64 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Gene, This is Mqcheng64 , I received the Gas Valve today from APP. and installed it, it's works few times and goes back same problem. what do i do next?Thanks Unlikely, but there is a small chance that the flame sensor contacts open prematurely. - The flame sensor Part number: AP2910747
Gene. P.S. Be aware that any unneeded parts purchased from Appliance Parts Pros can be return within 45 days.
Hi Gene, The gas valve came in today from App and I installed it. I tested a few times it's works fine. put everything back together and test a first load and went back same problems.Please advise , Thanks mqcheng64
Hi Gene, The gas valve came in today from App and I installed it right away. It's works first few tested.After I put it's together then test a first load and went back same problem.The ignitor glow for 20 seconds then goes out I could smell gas but no flame. Thanks
Hi gene, I checked with multimeter and there is contuinity in flame sensor. Perhaps Temperature control element broke.please advise,Thanks.
The possible problem with the flame sensor I mentioned in the previous post can not be proved by continuity test. I would just order it and give it a try.
