9 Pages«<23456>»
#31 Posted : Monday, January 31, 2011 1:46:28 PM(UTC)
Originally Posted by: mqcheng64 Go to Quoted Post
Maytag MDG8600AWW Dryer
Sounds like the problem is a bad gas valve itself.
- The gas valve Part number: AP4037259
MFSTOFFEL
#32 Posted : Monday, January 31, 2011 2:34:36 PM(UTC)
MFSTOFFEL
Got a gas dryer Whirlpool model SGDX600JQ2, the timer is not turning, heat will kick in for about 5 minutes, then the heat will shut off, the dryer will keep on turning all day if a do not shut it off manually. I need advise an what to part to buy. Matt
#33 Posted : Monday, January 31, 2011 5:20:58 PM(UTC)
Mr Matt,
Very likely the problem is a bad gas valve coils.
- The coil kit Part number: AP3094251
MFSTOFFEL
#34 Posted : Tuesday, February 1, 2011 6:57:35 AM(UTC)
MFSTOFFEL
Mr Matt,
Hi Gene,
I will order the parts to install, and keep you posted on the outcome. Thx for your quick response. Matt ;)
mqcheng64
#35 Posted : Thursday, February 3, 2011 3:11:45 PM(UTC)
mqcheng64
Hi Gene,
This is Mqcheng64 , I received the Gas Valve today from APP. and installed it, it's works few times and goes back same problem. what do i do next?Thanks
#36 Posted : Thursday, February 3, 2011 4:40:52 PM(UTC)
Hi Gene,
Unlikely, but there is a small chance that the flame sensor contacts open prematurely.
- The flame sensor Part number: AP2910747
P.S. Be aware that any unneeded parts purchased from Appliance Parts Pros can be return within 45 days.
mqcheng64
#37 Posted : Thursday, February 3, 2011 7:34:31 PM(UTC)
mqcheng64
Hi Gene,
The gas valve came in today from App and I installed it. I tested a few times it's works fine. put everything back together and test a first load and went back same problems.Please advise , Thanks mqcheng64
mqcheng64
#38 Posted : Thursday, February 3, 2011 7:43:53 PM(UTC)
mqcheng64
Hi Gene,
The gas valve came in today from App and I installed it right away. It's works first few tested.After I put it's together then test a first load and went back same problem.The ignitor glow for 20 seconds then goes out I could smell gas but no flame. Thanks
mqcheng64
#39 Posted : Friday, February 4, 2011 6:29:25 AM(UTC)
mqcheng64
Hi gene,
I checked with multimeter and there is contuinity in flame sensor. Perhaps Temperature control element broke.please advise,Thanks.
#40 Posted : Friday, February 4, 2011 12:23:40 PM(UTC)
The possible problem with the flame sensor I mentioned in the previous post can not be proved by continuity test. I would just order it and give it a try.
Gas Dryer running but no heat (Dryer Repair)
by cpenn42 8/26/2011 4:50:25 PM(UTC)
9 Pages«<23456>»
