Replacement parts for WHIRLPOOL KUDP02CRBS1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.comHere is the tech sheet,see attachment
Take a look at Section 2.
It could be the console (keypad) Item 1, the ribbon cable item 2, the interconnect board item 5 or the control board item 11.
If you look at the tech sheet you will see that the 3 keys you mentioned first all use P1-6 as a common.
You may want to try the following first.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the various connections between the 4 parts.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Clean the other connectors. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If the above does nothing check the ribbon cable and interconnect tracks for continuity using a meter.
If all OK then check the console (keypad) keys with the meter,see the tech sheet.
If the console fails then order that.
If all the above are OK then the control board is the most likely culprit.
Still a bit of a crap shoot but your odds are better if you can actually narrow down the fault.
If you do the above checks and order a part from AppliancePartsPros they will let you return the part if it does not fix your problem.
See their return policy.
