I Have A Ge Wsm2420d0ww That Has Never Been Used. Been Stored In Garage Since Brand New For Past 3 Years (?). We Hooked It Up Last Night And Everything Works Except For It Won't Stop Filling And Overflows. Suggestions? Thanks!
The water level switch could stuck. Move it forth and back - it might help. If not, then open the control panel and check the water pressure hose (clear plastic hose) connection to the water level switch. Post the results.
Took The Control Panel Off And There It Was. A Mouse Nest. They Chewed A Big Hole In The Clear Hose. Easy Fix. Thanks!
Darn mice get everywhere!
You are very lucky they did not chew drain or fill hoses. I've seen it many times.
I cleaned the clear hose on my GE washer and it works great now! Thank you soooooo much :) you just saved me a lot of money
Thanks again, Suzette
You are welcome Suzette. We're glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
