6 Pages«<23456>
richappy
#31 Posted : Sunday, July 11, 2010 4:56:19 PM(UTC)
richappy
You probably have stuff stuck in the motor pump, will have to pull dishwasher to pull it off.
Marc Center
#32 Posted : Saturday, January 22, 2011 7:10:01 AM(UTC)
Marc Center
How is lower washarm removed to access the previous mentioned procedure?
#33 Posted : Monday, January 24, 2011 12:46:48 PM(UTC)
Marc,
What is the complete model number of the dishwasher?
What exactly is wrong?
fourmasons1
#34 Posted : Sunday, January 30, 2011 12:32:17 PM(UTC)
fourmasons1
Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm.
Remove 4 screws (#3 on the break down diagram) holding the top cover (#1 on the break down diagram).
Remove the inlet protector (#8) holding by the tab on the right side.
Check the chopper (#6) for any clog.
Clean all debris and assemble in the reverse order.
Hi Gene, thanks for all th info. We got to the part where we need to remove the 4 screws, but we can't get to the 4th screw because it's underneath the water supply tube. How do you get to the 4th screw? Do you have to get the water supply tube off? We don't want to break anything. Our model number is Whirlpool Gold Quiet Partner II GU2300 XTSBO. Any help would be appreciated.
Steve
#35 Posted : Sunday, January 30, 2011 1:56:04 PM(UTC)
Steve,
You quoted my post but you probably did not read carefully. In the beginning it says: "...Remove the upper dish rack.
Remove the water feeding tube for the upper spray arm..."
Here are the breakdown diagrams and Upper wash and rinse parts replacement parts for WHIRLPOOL GU2300XTSB0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
atx4us
#36 Posted : Wednesday, February 16, 2011 8:02:41 PM(UTC)
atx4us
Originally Posted by: richappy Go to Quoted Post
You might have a clog going to the upper spray arm. You also may have a low water level, just dump an extra gallon in to see if it works
My Kenmore model # 665.13482K901 dishwasher was hardly even wetting the dishes. At the beginning of every new wash cycle, it would fill with water, then run for about 10 seconds, stops and fills with more water and then starts again. But, it still isn't enough water. I tried adding extra water with a bucket as suggested here and the dishwasher is spraying all the dishes as it should be.
How can I set the correct amount of fill water in this dishwasher? Thanks.
#37 Posted : Thursday, February 17, 2011 12:05:23 PM(UTC)
Originally Posted by: atx4us Go to Quoted Post
...I tried adding extra water with a bucket as suggested here and the dishwasher is spraying all the dishes as it should be.
Sounds like the problem is a bad water inlet valve. You can try to clean the screen inside it but the best solution is to replace it.
- The water inlet valve AP4433986
ljfreeze@optonline.net
#38 Posted : Monday, February 21, 2011 8:58:32 AM(UTC)
I have a whirlpool GU2400xtps1 and the chooper get filled with debris on a weekly basis. When i clean the chopper the dishwasher cleans well for a week. What could cause the chooper to get clogged so frequently?
richappy
#39 Posted : Monday, February 21, 2011 1:55:52 PM(UTC)
richappy
Try to turn the chopper, if it turns freely, it's bad, must turn with the motor impeller.
#40 Posted : Monday, February 21, 2011 2:20:04 PM(UTC)
The chopper is new. Only the outside metal wings? spin. I'm thinking it may be the check valve but why would the check valve fail. I've read that there is something that is supposed to flush the chopper. Maybe it is not being flushed properly?
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
6 Pages«<23456>
