bachlem
#1 Posted : Wednesday, January 19, 2011 9:27:21 AM(UTC)
bachlem
I have an old maytag washer, model LA712, It leaked oil out of the bottom of the transmission. So I ordered new seals from appliance parts pro, I installed the seals and in doing so, one seal is inside of the transmission. I had to take the transmission apart to do the job. I set it back together, and the agitator works fine, but something seems to be wrong because in the spin/rinse cycles, it just keeps on agitating, it does not spin. What did I do wrong and how can I fix it?
magician59
#2 Posted : Wednesday, January 19, 2011 10:13:47 AM(UTC)
magician59
What kind of oil did you put in it?
bachlem
#3 Posted : Wednesday, January 19, 2011 10:26:54 AM(UTC)
bachlem
I put "Maytag transmission oil"in it.
magician59
#4 Posted : Wednesday, January 19, 2011 11:10:40 AM(UTC)
magician59
This may just be coincidental to your repair. Have you checked the spin in all the timer cycles?
bachlem
#5 Posted : Wednesday, January 19, 2011 11:13:32 AM(UTC)
bachlem
yes, no spins, only agitation in all cycles.
magician59
#6 Posted : Wednesday, January 19, 2011 12:50:10 PM(UTC)
magician59
Just to eliminate the motor as suspect, Remove the belts and try a spin cycle. If the motor runs, the problem is definitely in the transmission.
Guest (6)
Kenmore/Whirlpool Series 80 Washer Transmission problems (Washer Repair)
by thrashercharged 4/3/2014 6:05:58 AM(UTC)
by Funfly2 11/14/2012 6:53:35 PM(UTC)
Transmission Problems? (Washer Repair)
by Derek Hinds 9/8/2011 1:00:37 PM(UTC)
Transmission Problems? Brake Problems? (Washer Repair)
by fonty 4/23/2010 1:14:02 PM(UTC)
Maytag Performa Transmission problems (Washer Repair)
by dubster 6/14/2009 9:56:20 AM(UTC)
