mac79
#1 Posted : Tuesday, September 9, 2008 9:34:12 PM(UTC)
mac79
Hello i have a older ge dryer the thing wasnt heating right so i took it apart bypassed the switch and turned it on to see if the heating element was not working. Both coils heat up , the top one stays on and the inner one goes out real quick, and they both quit working if i move the dial a bit either way. Even on timed heat it only works in a little section of the dial. I noticed it has three thermostats, well i think there thermostats. So my question is: is my timer bad or one of those thermostats. And i was wondering how i go about testing them. EDIT: my bad i just saw your post about testing continuity. i still need help though lol.
Thanks in advance
mac79
#2 Posted : Wednesday, September 10, 2008 11:09:18 AM(UTC)
mac79
anybody have any ideas what i should be testing, my wife is on me about this
thanks
libertyappl
#3 Posted : Wednesday, September 10, 2008 11:31:46 AM(UTC)
libertyappl
can you double check your model number it doesn't pull up.
Nat
mac79
#4 Posted : Wednesday, September 10, 2008 4:16:40 PM(UTC)
mac79
sorry i got a s and a 5 mixed up. its DDE7100SBLWW
SublimeMasterJW
#5 Posted : Wednesday, September 10, 2008 5:25:31 PM(UTC)
SublimeMasterJW
Some of those GE timers are very easy to fix. If your dryer has the timer with the 2 quick plugs on it, get the timer out of the dryer without being electrocuted. Remove the 2 screws that hold the timer motor on the timer plate and carefully take the cover off. Get a fingernail file clean the points. Put the alabama gloss and the mississippi shine on them electrical contacts. She will probably work beautiful. If not get another timer. But try filing the points on that puppy first. :D
mac79
#6 Posted : Wednesday, September 10, 2008 9:01:43 PM(UTC)
mac79
ok i will give it a try. I really appreciatte your help
