Melissa
#1 Posted : Tuesday, September 9, 2008 1:07:42 PM(UTC)
Melissa
My two-year-old GE oven, Model Number JSP42W0K4WW, is not responding all of a sudden to 3 of the buttons on the touch pad (bake, self-clean, and oven light). I found someone else on this site having the same problem with a different GE oven, and I assume I have the same problem. I've researched the part number for the touch pad, and I believe it is WB27T10483. Is that my problem, and is that the correct part number? Thanks you for any help you can provide!
Melissa
#2 Posted : Tuesday, September 9, 2008 4:58:53 PM(UTC)
Melissa
Gene responded to the other post, but it was about three months ago. Gene, you still here?
#3 Posted : Tuesday, September 9, 2008 5:41:24 PM(UTC)
Hi Melissa,
Most likely the problem is a bad key pad and if it's white then the part number you found is correct.
GE part number WB27T10483 is APP item number AP3204742
Melissa
#4 Posted : Tuesday, September 9, 2008 6:28:22 PM(UTC)
Melissa
If it's something else, any ideas what else it might be?
febrown
#5 Posted : Wednesday, September 17, 2008 4:51:16 PM(UTC)
febrown
I have a range model JDP36GP. Black. When I press the Bake or Broil buttons on the pad, the display blinks a couple of times and nothing else happens. Is this a common occurrence?
Does anyone know what the part number is and if there is an idiot sheet showing the procedure for removal and replacement?
Thanks:confused:
libertyappl
#6 Posted : Wednesday, September 17, 2008 6:20:45 PM(UTC)
libertyappl
febrown, What's the remainder of your model number?
febrown
#7 Posted : Thursday, September 18, 2008 4:57:08 AM(UTC)
febrown
I actually erred initially. The complete number is:
JDP37G0P18G it is black.
libertyappl
#8 Posted : Thursday, September 18, 2008 5:28:46 AM(UTC)
libertyappl
febrown,
I can't get the model number you posted to pull up. The closest I could come to get to that is JDP37GP3BG and the clock/control has been discontinued.
Nat
Guest (5)
