2 Pages12>
bjottsixx
#1 Posted : Monday, September 1, 2008 7:38:24 AM(UTC)
bjottsixx
No cooling at all. Fans run but compressor not working. Any thoughts where to start?
abadfish66
#2 Posted : Monday, September 1, 2008 7:48:48 AM(UTC)
abadfish66
Go to the back of the refrigerator, and remove the main board from behind the access cover. Look on the back of the board, is there a burn mark, if so you can either resolder it or get a new board. post your findings
bjottsixx
#3 Posted : Monday, September 1, 2008 7:55:40 AM(UTC)
bjottsixx
What actually hold the board once all the connectors are disconnected?
abadfish66
#4 Posted : Monday, September 1, 2008 7:57:14 AM(UTC)
abadfish66
there are 4 plastic pin, just get needlenose pliers, and sqeeze the pin while pulling the board out.
bjottsixx
#5 Posted : Monday, September 1, 2008 8:12:29 AM(UTC)
bjottsixx
Board came loose pretty easy - any suggestions for connectors?
bjottsixx
#6 Posted : Monday, September 1, 2008 8:24:05 AM(UTC)
bjottsixx
I've removed a couple of connectors to get access to the board and it does have a burned terminal on it - can it be re-soldered with the other connectors in place?
abadfish66
#7 Posted : Monday, September 1, 2008 8:31:34 AM(UTC)
abadfish66
Where is the burnt terminal?
abadfish66
#8 Posted : Monday, September 1, 2008 8:32:17 AM(UTC)
abadfish66
Just take the wire connections off the board, they pull off, and can only go back on one way
bjottsixx
#9 Posted : Monday, September 1, 2008 9:08:53 AM(UTC)
bjottsixx
Looks like the burned terminal is behind, what looks like, a relay box.
abadfish66
#10 Posted : Monday, September 1, 2008 9:17:59 AM(UTC)
abadfish66
Yep, that is your compressor relay. Now you can resolder it, I would say it is probably a 50-50 shot of getting the solder to adhere, but it's worth a shot, or you can just purchase a new board and put it in. Here is the board you need-------->Part Details - GE Main board assembly, part number: WR55X10552
Guest (6)
2 Pages12>
