Dale P
#1 Posted : Tuesday, December 21, 2010 5:28:04 PM(UTC)
Dale P
We have a Kenmore, model # 3638751581 refrig/ freezer. The freezer is on top and it has stopped getting cold. The fan seems to be blowing but there is no cold temp at all.. The bottom refer appears to be working perfectly.
#2 Posted : Wednesday, December 22, 2010 4:43:24 AM(UTC)
It is just a matter of time before the fresh food section warms up as it gets all it's cooling from the freezer.
Is the compressor running?
Usually you can hear it also you should be able to feel it vibrating and it should be warm.
If it is, remove the rear cover in the freezer so you can see the evaporator coils.
If they are heavily iced/frosted over, you probably have a defrost problem.
If there is just frost in one area usually where the freon enters the coils you rae probably low on freon.
Here is a good site with basic info on fridge repair and troubleshooting.
http://www.applianceaid.com/frig.html
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
SidexSide Fridge/Freezer not cold; tried to self-diagnose (Refrigerator & Freezer Repair)
by kenroehr 2/1/2018 6:10:10 AM(UTC)
Refrigerator & Freezer Not Cold - Evap Coils Frosted Over (Refrigerator & Freezer Repair)
by gciccol 12/13/2017 1:32:46 PM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Non-defrosting upright freezer not cold on bottom (Refrigerator & Freezer Repair)
by KOP264 6/12/2017 4:38:01 AM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
