clecun
#1 Posted : Sunday, August 24, 2008 2:17:46 PM(UTC)
clecun
my dish washer wont drain so i looked for a clog in the hose. I can not blow air through the house, houses all clear. I believe there is a check valve in the disposal where the hose hooks up and it is stuck. Any suggestions on getting this valve unstuck.
libertyappl
#2 Posted : Monday, August 25, 2008 1:29:25 PM(UTC)
libertyappl
Have you replaced the disposal recently?
clecun
#3 Posted : Monday, August 25, 2008 4:53:45 PM(UTC)
clecun
no i just moved into the house. Im thinking about just replacing the unit
libertyappl
#4 Posted : Monday, August 25, 2008 5:36:33 PM(UTC)
libertyappl
That might be a good idea, if you do make sure to knock the plug for the dishwasher out of the new disposal. I don't know how many calls we've had over the years for that.
clecun
#5 Posted : Monday, August 25, 2008 6:03:32 PM(UTC)
clecun
hmm you dont say. I wonder if that could be the problem with mine. I put my finger in the hole for the hose and it feels like there is a plug in there and i cant move it. If the plug was still in there what would be the easiest was to remove it.
libertyappl
#6 Posted : Monday, August 25, 2008 6:11:11 PM(UTC)
libertyappl
Remove the hose and use a big screw driver & hammer, make sure you get all of the plug out if that's what the issue is.
Hope that helps,
Nat
clecun
#7 Posted : Tuesday, August 26, 2008 10:58:22 AM(UTC)
clecun
it worked like a charm. thanks for your help.
libertyappl
#8 Posted : Tuesday, August 26, 2008 11:16:22 AM(UTC)
libertyappl
You're very welcome!
