TheGreenMachine79
#1 Posted : Sunday, December 5, 2010 1:24:08 PM(UTC)
TheGreenMachine79
I was on my second load yesterday and the washer shut down without completing the cycle and I noticed a burnt electronics smell. I waited a hour to let it cool down and I started it back up. Last winter I had the same problem with the drier, I ran it until it died, it ended up being the motor bearings that went bad and finally seized. I would like to figure out whats going bad on the washer so I can get the parts and fix it at my leisure before it dies. Can you guys give me some ideas of what it could be and what to look for? My first guess would be the motor/bearings.
sidfink43
#2 Posted : Wednesday, December 8, 2010 6:55:42 AM(UTC)
sidfink43
Since it started back up it seems like the motor is the problem, with its internal protection device shutting it down when the problem occurred.
This might be just a one time problem, so keep using it, but if it recurs try replacing the motor. It is also possible something in the transmission got hung up and caused the motor to overheat.
Kenmore 90 series washer spin problem (Washer Repair)
by NikoletteFancy 3/26/2015 5:51:18 AM(UTC)
kenmore 90 series washer parts (Washer Repair)
by rogerf1970 12/17/2014 7:43:40 AM(UTC)
Kenmore 90 Series Washer Fills then stops (Washer Repair)
Belarus Mike Rekker 3/10/2014 4:32:07 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Kenmore 90 Series washer buzz - dead (Washer Repair)
by ColdHands 1/26/2014 8:33:02 AM(UTC)
Kenmore 90 Series washer will agitate but won't spin (Washer Repair)
by Cowgirl4ever81 4/2/2013 8:24:55 AM(UTC)
Kenmore 90 series washer (Washer Repair)
by lego126 5/11/2012 7:45:28 PM(UTC)
by purplesunv 11/10/2011 12:26:56 PM(UTC)
Kenmore 90 series washer won't agitate nor spin (Washer Repair)
by dlynn25 7/17/2011 11:55:34 AM(UTC)
Kenmore 90 Series Washer Jumps when stopped (Washer Repair)
by 2358schwab 6/7/2011 7:41:56 AM(UTC)
kenmore 90 series washer agitates fine barely spins (Washer Repair)
by vbnitro2010 8/10/2010 8:56:32 PM(UTC)
Kenmore 90 series washer slams to a stop after spin cycle (Washer Repair)
by bobbycat71 7/18/2010 5:13:30 AM(UTC)
Kenmore 90 series washer will agitate but not spin or drain (Washer Repair)
by kmyres76 6/15/2010 1:35:05 PM(UTC)
by momof4 3/10/2010 5:20:37 PM(UTC)
Kenmore 90 Series Washer (Washer Repair)
by Mr Lee 1/16/2010 2:55:31 PM(UTC)
