thecass2
#1 Posted : Wednesday, December 1, 2010 11:15:40 AM(UTC)
thecass2
there is no water going to the ice maker, but i do have water going to the outside water dispenser on freezer door
semicolon1
#2 Posted : Wednesday, December 1, 2010 11:19:57 AM(UTC)
semicolon1
Did you ever find out what this was? Water inlet? I'm having the same problem.
magician59
#3 Posted : Wednesday, December 1, 2010 12:26:20 PM(UTC)
magician59
What is the temperature in the freezer?
mmetzing
#4 Posted : Thursday, December 2, 2010 5:01:02 AM(UTC)
mmetzing
I had the same problem and heres what I found...
I first checked the silenoid that the outgoing lines are attached to. You have 1 water line comming in connected to a valve with 2 outlets. (1 to the freezer and 1 to the water) each 1 of them are operated by a switch. If that switch is bad then it will not send water to that paticular line. Now, mine worked! But I still didnt get water to the freezer. After making sure the temp was at least 17 degrees (it wont start producing ice until it is "cold" enough) I found that I actually had a kinked line where it was connected to the outlet in the back of the refridgerator. Now after straightening out the kink, I am getting perfect ice.
Hope this helps! Im not a technician just a doityourselfer.
Guest (5)
No water going to ice maker (Refrigerator & Freezer Repair)
by tag106 7/30/2008 9:11:57 AM(UTC)
