2 Pages<12
scotty tagfixer
#11 Posted : Saturday, November 13, 2010 11:35:13 AM(UTC)
scotty tagfixer
Ordered relay today.
Wanted the overload but the one pictured is incorrect and they dont know of any other .
I have two brass terminals on my overload.
The one shown has one side shortened.
I can get correct overload locally I hope, at least thats what they said.
scotty tagfixer
#12 Posted : Thursday, November 18, 2010 9:04:36 AM(UTC)
scotty tagfixer
Received relay faster than expected.
Installed and is running differently, compressor running independently of condenser fan now.Seems much more normal.
Still tho seems like a lot of cycling on and off.
When hearing the condenser fan motor run, there are occasional brief interuptions (Like would be incurred by a loss of power) and after those blips the systems stops.
About 10-15 seconds later, sytem will start up again.
eventually it stops cycling and goes quiet for a while.
cooling fine no over cooling or other issues.
Wondering if thermostat could be acting up.
Could a bad door seal be issue?
Any ideas?
Thanks Richappy
richappy
#13 Posted : Friday, November 19, 2010 12:56:59 AM(UTC)
richappy
You have a cold control behind the control panel and a defrost control near the compressor. Tap on both of them to see which one is intermittent.
scotty tagfixer
#14 Posted : Saturday, November 20, 2010 7:40:12 AM(UTC)
scotty tagfixer
been hearing clicking from control panel and when "tapped", notice it does interrupt power to rest of system.
checked resistance between terminals, either infinity or .02 no incremental increase as dial is turned. rusty and corroded, dont look too good.
believe that is where the issue is.
Thanks Richappy.
scotty tagfixer
#15 Posted : Sunday, November 21, 2010 8:53:11 AM(UTC)
scotty tagfixer
no way to remove bottom freezer tray without destroying it.
will install new temp control and go from there.
If need to change defrost thermo, most techs replace bottom tray?
may get out the hole saw/dremel tool if I new exactly where the stat was.
scotty tagfixer
#16 Posted : Wednesday, November 24, 2010 3:19:51 PM(UTC)
scotty tagfixer
Ordered cold control and defrost thermo.
they arrived today.
defrost thermo on shelf.
Installed cold control this afternoon and so far, it acting normal.
WOOHOOO!!!!
Thanks Richappy.
You the man!!!:D
2 Pages<12
