rob
kemps8
#1 Posted : Monday, November 15, 2010 11:02:08 AM(UTC)
kemps8
i went to turn on the cooktop light and the bulb made a pop louder than when a light bulb normally goes out. i got a new bulb and it still doesn't work. i checked the voltage to the socket and have 2 volts all the time. nothing changes when i push the off/low/high button. everything else works fine. any idea or help would be greatly appreciated.
magician59
#2 Posted : Monday, November 15, 2010 11:06:03 AM(UTC)
magician59
You got a model number? Sounds like a dead short. These are sometimes caused by critters. A model number will help us to see how your model is wired.
kemps8
#3 Posted : Monday, November 15, 2010 11:10:05 AM(UTC)
kemps8
amv1162aaw
magician59
#4 Posted : Monday, November 15, 2010 11:28:35 AM(UTC)
magician59
Ok. I'm a little confused. I thought you were referring to a vent hood light. Did you check the circuit breaker? Have you checked all the other functions of the microwave? Do you have power to the display? Will it accept cook commands?
kemps8
#5 Posted : Monday, November 15, 2010 12:19:05 PM(UTC)
kemps8
everything works just not the light.
magician59
#6 Posted : Tuesday, November 16, 2010 5:43:42 AM(UTC)
magician59
You probably have a disconnected socket, or when the light blew, it burnt through a wire lead. You'll need to uninstall the microwave and remove the cabinet cover (10 or more screws) to access the socket.
Kenmore series 500 brake release problem (Washer Repair)
by walbar1516 6/29/2024 10:20:56 AM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
Kitchen Aid Electric Rang Power Problem (Oven Repair (including Ranges and Cooktops))
by Guest 3/10/2024 7:24:24 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
Robert Shaw Fireplace Gas Valve - Sticks (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 11/15/2023 4:04:14 PM(UTC)
kenmore refrige problems (Refrigerator & Freezer Repair)
by jkoppen73 11/13/2023 6:58:09 AM(UTC)
Refrigerator Valve or Computer Problem? (Refrigerator & Freezer Repair)
by fallman237 10/8/2023 2:22:06 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Speed Queen washer problem (Washer Repair)
by Guest 7/21/2023 1:04:45 PM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
