Jon P
#1 Posted : Wednesday, August 6, 2008 6:44:24 PM(UTC)
Jon P
Our dryer quit. It does nothing at all. No heat, drum doesn't turn, nothing. I tested the door switch and it is good. I also checked the breaker in my fuse box. There is no noise what so ever, not even a click. Timer settings or temp settings don't matter either. I was thinking maybe a start switch-relay?
richappy
#2 Posted : Thursday, August 7, 2008 1:41:10 AM(UTC)
richappy
Verify 230 volts to the dryer, then check the thermal fuse, a narrow white plastic item on the blower housing.
Jon P
#3 Posted : Saturday, August 9, 2008 12:41:49 PM(UTC)
Jon P
richappy,
I have 230v to the dryer. So I tested that thermal fuse and found it is open. I ordered a new one and hope that is all that is wrong with it. Any reason why they fail? Old age? Thanks for your help. Much cheaper than replacing the dryer.
richappy
#4 Posted : Sunday, August 10, 2008 3:03:40 AM(UTC)
richappy
Sometimes they just wear out. You should check your ducting for a partial restriction that can overheat the dryer.
