sling
#1 Posted : Friday, August 8, 2008 2:49:49 PM(UTC)
sling
Hi, the door of my front loader won't lock, I have replaced the striker, but the part inside that receives it needs to be replaced. I have ordered the part, but do not know how to take the front of the washer off. Any help would be greatly appreciated!
abadfish66
#2 Posted : Friday, August 8, 2008 2:53:06 PM(UTC)
abadfish66
The model# does not come up, can you check and repost
sling
#3 Posted : Friday, August 8, 2008 2:58:19 PM(UTC)
sling
ATF6000ES1 Frigidaire Affinity Front Load Washer. I am sure of the model #. Thanks
abadfish66
#4 Posted : Friday, August 8, 2008 3:00:24 PM(UTC)
abadfish66
I believe you dont need to remove the front to change it. Look at the front of the rubber boot that attaches to the front of the washer, there may be a ring around it with a spring attached, if so, remove the ring and pull the boot off the front lip. with this off you should be able to unscrew the latch bracket and pull it over to disconnect the wiring and install the new one.
sling
#5 Posted : Friday, August 8, 2008 3:02:44 PM(UTC)
sling
I will give that a try - it makes sense. Thanks!!
sling
#6 Posted : Friday, August 8, 2008 4:33:23 PM(UTC)
sling
i can't figure how to pull it out. there is a finger hole - don't see a spring. any tips?
abadfish66
#7 Posted : Friday, August 8, 2008 5:01:18 PM(UTC)
abadfish66
Pull what out?
misterfixall
#8 Posted : Friday, August 8, 2008 5:24:22 PM(UTC)
misterfixall
when you recieve the door latch the installation instruction should come with it
sling
#9 Posted : Friday, August 8, 2008 5:35:44 PM(UTC)
sling
TO PULL OUT THE BOOT (QUEST FROM ABADFISH66)
Thanks for the note that instal instruct will come with part.
Guest (6)
