Hi,
I have a GBD307PDS09. Started seeing the E6 F2 error. Did some troubleshooting based on this thread.
Cleaned contacts in ribbon cable
E6 F2 came back after power on
Verified good power at board and at transformer (120V)
Transformer output was 23V
disconnected ribbon and turned power off and back on
Saw E1 F2
After a while decided to try to see what would happen so plugged in ribbon cable
Oven seemed to work fine
Display was intermittent but oven still functioned
THis morning display was blank, but buttons still worked and oven started fine. Display came back once I pressed buttons. still blanks out every few minutes.
appliance part pros said it would be 2 weeks to get a new control panel.
I really need oven over Christmas so wondering what I can do to help keep it going.
As I said above, display was blank but when I pressed the "Bake" button lights came on and I hit start and it all worked.
I let it run for about 15 min then turned it off
DIsplay was normal, then after being off about 5 minutes, got the beeps and display went to E6 F2 but on again off again (intermittent but almost a very slow blink)
Unplugged ribbon and reset power.
Got E1 F2 but after about 45 minutes, beeped and reverted back to E6 F2
Since the control board seems to be backordered everywhere with weeks or more delay, I was looking at this site
http://www.************************.com/index.html (fixyourboardDOTcom)
They will repair the current board in a few days. This may be a better option anyone tried this? Before I do this and therefore stop troubleshooting, is there anything else it could be? The intermittent nature of this is troubling
Also, based on receipts from the previous owner of the house (the oven is only5 years old) the "CTRL board and fuse link" was replaced in May, 2008. Pretty poor product if it needs to be replaced twice in 5 years. Could there be another component that is causing a premature failure?
thanks
Bob
