SJSonARF
#1 Posted : Thursday, October 21, 2010 9:16:42 AM(UTC)
SJSonARF
The control panel display on this oven is completely dead. My wife was using the the microwave oven, and while pressing the EASY MINUTE button, the oven made a crackling noise for a second or two then stopped working, with the control panel display blank (unlit) and unresponsive. I was in another room at the time, in which the lights flickered then returned to normal. There was no unusual odor at the time of the failure.
The circuit breaker to the oven was not tripped and turning off the breaker for several minutes had no effect.
The oven light turns on when the door is opened.
The 250V 20A fuse appears to be okay, showing 0 ohms on a multimeter.
I assume the control panel (AP3598629, Whirlpool 8301991) has failed, but before I order and install this part, I'd like to make sure that make sure that this is the most likely cause, and not some other electrical component.
Would any of the other components (capacitor, supressor, transformers, magnetron, etc.) cause it to fail in this way?
magician59
#2 Posted : Thursday, October 21, 2010 9:56:51 AM(UTC)
magician59
If there's no display, but the light comes on; chances are that the low voltage transformer. This is probably now an integral part of the control board, so board replacement will be necessary.
Part number: AP3598629
SJSonARF
#3 Posted : Thursday, October 21, 2010 10:52:59 AM(UTC)
SJSonARF
Thanks Magician,
My main concern is that I might fry a new board if the problem was some other component. Not to mention not fixing the problem with a $$$ item when a $$ part would do it or at least is necessary.
There does appear to be a separate transformer for the control, WHIRLPOOL 9760589 (AP3963951) - TRANSFORMR.
Any help is greatly appreciated.
magician59
#4 Posted : Thursday, October 21, 2010 11:22:12 AM(UTC)
magician59
That is probably the transformer I'm talking about. You'll need to take a live voltage test with a meter to comfirm the diagnosis, before committing to a purchase. Do you feel comfortable doing such a test?
SJSonARF
#5 Posted : Thursday, October 21, 2010 1:53:15 PM(UTC)
SJSonARF
Magician,
I'm fine with performing the test, although the only real electrical work I've done has been with house wiring.
magician59
#6 Posted : Friday, October 22, 2010 5:18:30 AM(UTC)
magician59
The first thing to check is the incoming voltage and the voltage coming from the transformer. You should have 120VAC going to it; and something in the range of 10VAC coming out of it.
Control panel dead (Oven Repair (including Ranges and Cooktops))
by krome9 11/6/2017 10:57:18 AM(UTC)
Kenmore Elite refridgerator control panel dead (Refrigerator & Freezer Repair)
by MarshalW 9/2/2016 5:07:59 AM(UTC)
Jenn Air Stove/Convection/Oven Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by moboney 12/26/2015 7:37:27 AM(UTC)
GE Stove control panel dead (Oven Repair (including Ranges and Cooktops))
by PeterC-Oss 8/18/2015 10:49:04 AM(UTC)
Maytag Gas Stove Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by bullcitybob 1/1/2014 12:45:27 PM(UTC)
by jthunder 9/11/2012 7:42:15 AM(UTC)
Maytag electric wall oven control panel dead (Oven Repair (including Ranges and Cooktops))
by sandiegan 3/24/2012 3:37:37 PM(UTC)
by davwwong 3/11/2012 8:39:02 AM(UTC)
Frigidaire Range Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by Bruce7799 12/15/2011 5:11:43 PM(UTC)
Control Panel Dead (Washer Repair)
by cumin 5/24/2011 8:25:37 AM(UTC)
Control panel dead following power outage (Oven Repair (including Ranges and Cooktops))
by Daniel J 2/16/2011 7:09:56 AM(UTC)
Frigidaire control panel dead (Dishwasher Repair)
by richappy 9/15/2010 11:12:59 AM(UTC)
control panel dead/ will not light (Dryer Repair)
by kpl 8/12/2010 3:02:28 PM(UTC)
whirlpool double oven control panel DEAD! (Oven Repair (including Ranges and Cooktops))
by dozija 1/1/2010 7:49:08 AM(UTC)
Whirlpool Stove-Control Panel Dead?? (Oven Repair (including Ranges and Cooktops))
by danmcnally 12/15/2008 4:12:36 PM(UTC)
