JNOLES
#1 Posted : Wednesday, September 19, 2007 7:41:21 AM(UTC)
JNOLES
The washer is not spinning but it is agitating. I checked the coupler and it spins fine. I turned the washer on with the side cover and the center plastic cover that goes over the shaft removed and you can see the clutch spin but the shaft is not moving. Any idea as to what it may be.
Matt / APP Team
#2 Posted : Wednesday, September 19, 2007 3:24:59 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
Here is the parts breakdown: Parts list
I would suspect the lid switch or the lid switch strike.
Click here: Lid switch
Click here: Lid switch bumper
You can test the lid switch for continuity and I believe the lid hinge activates the switch so look and make sure the bumper didnt fall off.
Whirlpool Gold direct drive washer (Washer Repair)
by brettjknotts 8/14/2023 10:49:26 AM(UTC)
Whirlpool top load direct drive washer LSR7300PQ0 (Washer Repair)
by Guest 6/15/2022 3:57:06 PM(UTC)
110.24622300 direct drive washer wont agitate or spin motor hums (Washer Repair)
by Guest 10/10/2021 7:32:00 PM(UTC)
Whirlpool Direct Drive Washer GSX9750P Pulsing-Cycling Motor RPM (Washer Repair)
by Motobene 8/15/2020 8:34:41 AM(UTC)
Kenmore Elite Direct Drive Washer Noisy at start of spin cycle (Washer Repair)
by FixitFan 9/17/2019 7:46:17 AM(UTC)
Inglis direct drive washer shakes and vibrates (Washer Repair)
by yellowcat08 7/14/2019 5:19:41 PM(UTC)
Direct drive washer burning smell- NOT the motor (Washer Repair)
by robmill3r 12/14/2017 7:32:32 AM(UTC)
Kenmore direct drive washer banging (Washer Repair)
by ramartin525 7/16/2017 8:34:12 AM(UTC)
Burning smell and not pumping out completely - Whirlpool direct drive washer (Washer Repair)
by dwizum 3/16/2017 5:56:53 AM(UTC)
Direct drive washer won't go to high speed spin (Washer Repair)
by xrc0000 4/14/2015 2:12:01 PM(UTC)
Whirlpool direct drive washer makes ratchet noise while spinning (Washer Repair)
by washergirl2014 3/18/2014 11:13:58 AM(UTC)
Whirlpool Direct Drive Washer Motor Coupling (Washer Repair)
by AwakenSatori 7/7/2013 3:44:40 PM(UTC)
Whirpool direct drive washer issues (Washer Repair)
by wadetrane 2/9/2013 8:48:32 PM(UTC)
Direct Drive Washer Agitator Only Turns Clockwise (Washer Repair)
by Rog47 9/27/2012 4:31:45 PM(UTC)
Whirlpool direct drive washer won't spin (Washer Repair)
by sarcza 3/6/2012 12:09:58 PM(UTC)
