AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool top load direct drive washer LSR7300PQ0
Hi!
I had an issue with the whirlpool top load direct drive LSR7300PQ0 washer not agitating so replaced the agitator dogs. The washer worked for a few loads then would fill with water and hum. Replaced drain pump and motor coupling but still would not work. Then replaced the clutch, the washer worked for half a cycle then had the same problem again. New agitator assembly, new drain pump, new clutch, new motor coupling, new hoses. All parts are installed correctly. Any suggestions?
Oh, also replaced the lid switch and burnt connector to no avail
Washer Repair
