notimetowait
#1 Posted : Friday, October 1, 2010 6:26:06 PM(UTC)
notimetowait
tested element good. tested thermalfuse good. tested high temp cutouts good. one of the temp cutouts #341146 had continuity but was sitting in a black plastic looking housing with a white and purple wire attached and there was not continuity at these terminals part #61894 (whirlpool number) Question is, is this part normally open and what is it? it was not connected with the normal red wires that the over temp. devices or the fuse had.
thank you,
NOTIMETOWAIT
#2 Posted : Saturday, October 2, 2010 1:03:52 AM(UTC)
A model number may help others help you.
Model Number Locator
L1 to L2 should be 240 volts
If OK
If OK
341146 is the main cycling thermostat.
61894 is a thermostat heater. Usually they are around 7,000 ohms.
When you request a lower temperature, this is heated up which adds heat to the cycling thermostat which then cycles more often resulting in less dryer heat.
It should not cause you to have no heat if it is blown. You were probably on loo low a meter scale to get a reading on it.
Kenmore Series 80 Electric Dryer not heating (Dryer Repair)
by Steven7171 3/30/2014 5:07:52 PM(UTC)
Electric Dryer Not Heating (Dryer Repair)
by bselff 12/20/2011 12:58:18 PM(UTC)
Estate(Whirlpool) Electric Dryer not heating (Dryer Repair)
by JDB59 11/23/2011 2:05:23 PM(UTC)
by inneedofhelpplease 3/17/2011 4:03:02 PM(UTC)
Whirlpool Electric Dryer not heating (Dryer Repair)
by choover1119 3/13/2011 11:02:32 AM(UTC)
Amana electric dryer not heating up (Dryer Repair)
by Ultraman50 1/6/2011 6:58:54 PM(UTC)
Maytag electric dryer not heating up (Dryer Repair)
by jmlpa 12/7/2010 9:41:11 AM(UTC)
by hrose 5/19/2010 5:45:56 PM(UTC)
by 18wheeler 1/30/2010 9:16:47 AM(UTC)
Electric dryer not heating (Dryer Repair)
by phut 1/21/2010 4:30:21 PM(UTC)
by glopez01 12/7/2009 12:41:37 PM(UTC)
Electric Dryer Not heating (Dryer Repair)
by Danske 11/23/2009 4:19:41 PM(UTC)
Electric Dryer Not Heating (Oven Repair (including Ranges and Cooktops))
by bkeiger 7/31/2009 12:27:48 PM(UTC)
electric Dryer not heating (Dryer Repair)
by RJ Trucks 7/28/2009 10:52:36 AM(UTC)
by Global Kiss 7/16/2009 10:33:02 AM(UTC)
