21 Pages«<34567>»
w2002s
#41 Posted : Tuesday, July 22, 2008 8:59:31 AM(UTC)
w2002s
Gene , yes the wires was remove , also there were 120v at both elements
#42 Posted : Wednesday, July 23, 2008 1:46:17 PM(UTC)
w2002s,
Check if there is 120VAC between the red wire (R-1 on the wiring diagram) at the control board and ground. If the reading is wrong then one of two 120VAC legs to the oven is missing. It could be the circuit breaker or a broken wire.
w2002s
#43 Posted : Thursday, July 24, 2008 9:01:51 AM(UTC)
w2002s
Gene, I check R1 to ground there is 120 v. from BLK 6 to ground at the control 120v . 240v going in.
#44 Posted : Thursday, July 24, 2008 7:26:48 PM(UTC)
w2002s,
There is proper power to everything in the oven, according to your reports. You just replaced the EOC.
The oven is still not working with unknown error code -1- which I never heard for all my life. Double check all electrical connections and components and if there is nothing wrong, call a certified technician.
Monk
#45 Posted : Sunday, July 27, 2008 2:35:07 PM(UTC)
Monk
my crosley gas range wouldn't come up to temp. I replaced the complete clock/relay and things worked fine. Now working for 3 months and an F1 error code comes on approx once a day and beeps? In the middle of the night when the oven is non operational. Can anyone help?:mad:
#46 Posted : Monday, July 28, 2008 2:05:22 PM(UTC)
Hi Monk,
What is the complete model number of the range?
Monk
#47 Posted : Monday, July 28, 2008 7:22:30 PM(UTC)
Monk
Hi Monk,
Hi Gene,
Crosley CG3478XRW s/n 14C328109284
Thx,
Monk
#48 Posted : Wednesday, July 30, 2008 2:47:07 PM(UTC)
Hi Monk,
Most likely the problem is a bad touch pad.
- The part number for the control panel is AP304866
Here are the break down diagrams for the Crosley range Model CG3478XRW
after5ive
#49 Posted : Wednesday, July 30, 2008 3:51:44 PM(UTC)
after5ive
i have a thermodor sc302tb double wall oven with a f2 error code. i called
thermodor and they are no help. do you have any suggestions
#50 Posted : Wednesday, July 30, 2008 4:10:09 PM(UTC)
The "F2" error code means "temperature runaway detected by the control".
For which oven, upper or lower, the error code was shown?
In which mode: time of the day, cooking or self cleaning the error code was shown?
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 9/7/2010 5:56:53 AM(UTC)
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:58:30 PM(UTC)
by emidgette 6/1/2010 4:56:50 PM(UTC)
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 9/1/2009 4:51:40 PM(UTC)
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 6/25/2009 5:47:37 AM(UTC)
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 1/14/2009 9:31:27 AM(UTC)
by cndybkr 9/29/2008 12:13:03 PM(UTC)
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 11/15/2007 6:43:00 PM(UTC)
21 Pages«<34567>»
