bstoffel
#1 Posted : Tuesday, July 22, 2008 4:46:40 PM(UTC)
bstoffel
I turned on disposer tonight and it worked fine as ususal. But after I turned off the switch, the unit continued to run. Had to unplug the unit from the wall under the sink to get it to shut off. I tried it again after 30 minutes and it still continues to run. Whats next, please?
Admin / APP Team
#2 Posted : Tuesday, July 22, 2008 9:51:39 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
Sounds like the on/off switch went bad and is constantly supplying power to the wall socket when ON or OFF. I'd check that first.
Leaking Garbage Disposer (Garbage Disposer Repair)
by ebdunn 9/27/2011 9:44:48 AM(UTC)
Garbage Disposer Turn Off (Garbage Disposer Repair)
by baldridge 2/14/2011 4:52:12 AM(UTC)
garbage disposer (Dishwasher Repair)
by ish2008 10/14/2010 8:39:44 AM(UTC)
GE garbage disposer not working (Garbage Disposer Repair)
by jdgolf 12/25/2009 7:48:18 AM(UTC)
Ge Garbage Disposer (Garbage Disposer Repair)
by MILLERHOME 12/21/2008 6:08:46 PM(UTC)
by Clifton Addison 8/29/2008 8:32:54 AM(UTC)
by Clifton Addison 8/29/2008 8:23:39 AM(UTC)
garbage disposer hums and no longer works (Garbage Disposer Repair)
by blawden 5/1/2008 12:30:48 PM(UTC)
Garbage Disposer leaks (Garbage Disposer Repair)
by papasmurf 1/2/2008 2:22:53 PM(UTC)
