21 Pages«<23456>»
#31 Posted : Sunday, July 20, 2008 12:39:57 PM(UTC)
w2002s,
What was the original problem?
What is the complete model number of the oven?
w2002s
#32 Posted : Sunday, July 20, 2008 1:05:48 PM(UTC)
w2002s
the original problem had an error code -1-.I replaced the EOC, now theres is still no heat. the model # is figidare FEB24S5ABB
#33 Posted : Sunday, July 20, 2008 1:11:17 PM(UTC)
Originally Posted by: w2002s Go to Quoted Post
... had an error code -1-...
You probably mistyped?
w2002s
#34 Posted : Sunday, July 20, 2008 1:43:40 PM(UTC)
w2002s
the eoc were replaced .but the oven still not heating up. The clock work , buttom works. what do you think the problem is.
#35 Posted : Sunday, July 20, 2008 9:32:22 PM(UTC)
What was an error code shown originally on the display?
w2002s
#36 Posted : Monday, July 21, 2008 8:26:16 AM(UTC)
w2002s
Hi Gene ,the error code on the display was -1- this is no type error
fishnugget
#37 Posted : Monday, July 21, 2008 10:49:18 AM(UTC)
fishnugget
I am getting this code on my double oven. RBD276PDB12
What should I do? What parts do I need? How hard is it to do?
#38 Posted : Monday, July 21, 2008 11:47:45 AM(UTC)
w2002s,
According to the wiring diagram there is a safety thermostat (#141 on the break down diagram) which, if it's open, interrupts power to both heating elements. I'm not sure where it's located. It could be on top of the oven (behind the control panel) or on the back of the oven.
- The part number for the safety thermostat is AP2145826
w2002s
#39 Posted : Monday, July 21, 2008 2:51:12 PM(UTC)
w2002s
Hi Gene I check the safety thermostat with a digital ohm meter across the two prone it displayed 00.0. do that indicate a closed circuit?
#40 Posted : Monday, July 21, 2008 3:15:39 PM(UTC)
Did you disconnect wires from the thermostat prior to testing?
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 9/7/2010 5:56:53 AM(UTC)
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:58:30 PM(UTC)
by emidgette 6/1/2010 4:56:50 PM(UTC)
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 9/1/2009 4:51:40 PM(UTC)
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 6/25/2009 5:47:37 AM(UTC)
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 1/14/2009 9:31:27 AM(UTC)
by cndybkr 9/29/2008 12:13:03 PM(UTC)
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 11/15/2007 6:43:00 PM(UTC)
21 Pages«<23456>»
