wedrons
#1 Posted : Tuesday, July 15, 2008 11:08:18 AM(UTC)
wedrons
I'm replacing the transmission and since there was some oil in the center post (the clutch drive tube slides through it) what type and weight of lube should I put in it and how much?
Thanks,
wedrons
richappy
#2 Posted : Wednesday, July 16, 2008 1:42:08 AM(UTC)
richappy
I use light turbine oil, non-detergent available in a squeeze tube from most appliance parts suppliers.
Also, I put some silicone grease under the upper spindle seal. I never pull the spin tube out all the way, never necessary. Make sure you clean off all rust areas on the tranny spindle before installing.
wedrons
#3 Posted : Wednesday, July 16, 2008 5:32:09 PM(UTC)
wedrons
Thanks Rich,
Going to use 20ND since the closest appliance store is 130m rt. How far up the tube do u fill it?
Skip
