2 Pages12>
vuacorona
#1 Posted : Sunday, June 29, 2008 8:03:05 PM(UTC)
vuacorona
Hi All,
My Whirlpool dishwasher DU890SWLQ0 is acting up. The motor is not started, and the water does not drain.
The motor has 4 pins, I tested continuity on the motor and it seem to be fine.
Please advise what else do I need to test?
Vua
#2 Posted : Monday, June 30, 2008 1:46:25 PM(UTC)
Hi Vua,
Does the motor hums?
If it does then the problem is a stuck pump which has to be replaced in such case. In order to do it the dishwasher has to be removed from the cabinet.
- The part number for the pump & motor assembly is AP3044239
Here are the break down diagrams for the Whirlpool dishwasher Model DU890SWLQ0
vuacorona
#3 Posted : Monday, June 30, 2008 3:56:17 PM(UTC)
vuacorona
Hi Vua,
Hi Gene and All,
thank you for your promptly replied.
yes the motor was hum for a bit, and now it stays silence.
Can you or anyone show me how to test this motor to make sure it is a dead motor.
richappy
#4 Posted : Tuesday, July 1, 2008 1:59:36 AM(UTC)
richappy
Remove the torq screws holding down the pump cover and check for objects jamming the pump impeller.
#5 Posted : Tuesday, July 1, 2008 1:53:45 PM(UTC)
Originally Posted by: vuacorona Go to Quoted Post
...The motor has 4 pins, I tested continuity on the motor and it seem to be fine...
How did you do it?
You have to check for continuity between the "W-V" and "GY", "Y" & "BU-W".
Check for 120VAC between the "BU-W" and neutral while the control calls for wash and the door is latched.
Post the results.
vuacorona
#6 Posted : Tuesday, July 1, 2008 2:19:45 PM(UTC)
vuacorona
How did you do it?
Post the results.
What I did was test the continuity between all 4 pins in the motor.
Now can you elaborate about "W-V", "GY", "Y", "BU-W"
Sorry for an amateur question, because I am one and still learning.
v.
#7 Posted : Tuesday, July 1, 2008 2:31:49 PM(UTC)
...Now can you elaborate about "W-V", "GY", "Y", "BU-W"...
These are the colors of the wires plugged into the motor plug. "W-V" - white with violet strip, "GY" - grey, "Y" - yellow and "BU-W" - blue with white strip. You have to check for continuity between the motor terminals according to the wire colors on the plug.
vuacorona
#8 Posted : Saturday, July 12, 2008 11:24:41 AM(UTC)
vuacorona
Hi Gene and All,
I checked for continuity at the motor terminals according to your instruction, and all 4 for pins have continuity to each other. So is this normal or something wrong with the motor?
vuacorona
#9 Posted : Saturday, July 12, 2008 12:11:12 PM(UTC)
vuacorona
Hi Gene and All,
I also tried to turn the motor impeller as in the image below in both direction, but it stuck after little moved.
UserPostedImage
vuacorona
#10 Posted : Sunday, July 13, 2008 2:15:36 PM(UTC)
vuacorona
All right, I just took the motor and the pump apart, and now the motor impeller can freely turning just fine.
However something stuck inside the pump that won't let the pump freely turning. This pump is appears to be sealed, how can I look inside the pump to see what stuck in there.
Guest (5)
2 Pages12>
