8 Pages«<34567>»
#41 Posted : Monday, August 30, 2010 7:08:49 PM(UTC)
You are welcome. I'm glad you were able to fix it and it was that simple.
pickett05
#42 Posted : Monday, February 21, 2011 8:52:29 PM(UTC)
pickett05
Our whirlpool dishwasher is not draining either. Like someone mentioned above, we could push the cancel/drain button and it would drain but now it doesnt even drain when we do that. We have checked for clogs and kinks in the hoses and there is nothing wrong. It is less then 2 years old.
#43 Posted : Tuesday, February 22, 2011 12:54:10 PM(UTC)
What is the complete model number of the dishwasher?
pickett05
#44 Posted : Tuesday, February 22, 2011 4:11:44 PM(UTC)
pickett05
The model number is DU1055TSQ3.It is a whirlpool quiet partner I. THanks in advance for you help.
#45 Posted : Tuesday, February 22, 2011 5:18:56 PM(UTC)
Remove the bottom panel and check if the drain pump works when it comes to drain.
If it does not, remove the wires from the drain pump and check for 120 VAC between them while the control calls for drain.
If the voltage reading is correct, replace the drain pump.
If the voltage reading is incorrect, check the wires between the control board and the drain pump.
If the wires are good, replace the control board.
- The drain pump Part number: AP3865489
pickett05
#46 Posted : Tuesday, February 22, 2011 5:43:19 PM(UTC)
pickett05
Thanks so much Gene for your help! We really appreciate it and will let you know what the outcome is.
loughclan
#47 Posted : Wednesday, April 27, 2011 7:38:34 AM(UTC)
loughclan
Model DU810SWPQ0. Will not drain. I have a disposal but its not new and the drains are clear. This problem just started this past weekend. The dishwasher is also making weird noises when it runs that I have not noticed before. May be time for a new one. This one is around 7 years old. Builder put it in, so I am sure it is cheap! I have pulled the bottom panel off but not sure what to do from here. I can push on the big drain line and it makes the water in the dishwasher "gurgle" and move. There is no air trap on top of the sink, but under the sink there is a pipe coming up and it has a vent in the top. I saw alot of posts where check valves were a problem, maybe that is my problem, just no clue where it is. Thanks for the help!
#48 Posted : Wednesday, April 27, 2011 1:54:20 PM(UTC)
Does it wash?
If it does, then remove the drain hose form wherever it is connected under the sink. Put the end of the hose in a bucket and run the drain cycle to see how it will do it. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DU810SWPQ0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
loughclan
#49 Posted : Wednesday, April 27, 2011 2:48:28 PM(UTC)
loughclan
Yes it does wash, but since it will not drain, they are still dirty. I was looking under the sink for the drain line and I did not see it. It should be attached to the disposal, correct? I will look again when I get home, but from looking underneath the dishwasher, it looks like the drain is going down thru the floor.
loughclan
#50 Posted : Wednesday, April 27, 2011 5:36:20 PM(UTC)
loughclan
OK. The drain line does go into the disposal. I unhooked it and nothing came out but it sounded like the dishwasher was pumping. The line is a see thru line and there is nothing blocked up in it.
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
New Whirlpool Dishwasher not draining (Dishwasher Repair)
by Maggy540 12/26/2012 8:55:49 AM(UTC)
Whirlpool Dishwasher not draining entirely (Dishwasher Repair)
by johnwartjr 2/28/2012 6:33:16 AM(UTC)
Whirlpool dishwasher not draining during wash cycle (Dishwasher Repair)
by krausjw 6/5/2011 6:10:04 AM(UTC)
by miketran 1/27/2011 5:50:35 PM(UTC)
by Tubhot2 1/23/2011 9:53:57 AM(UTC)
by Cappsfam 3/21/2010 7:22:43 PM(UTC)
Whirlpool Dishwasher Not Draining (Dishwasher Repair)
by fiorillo 12/8/2009 5:29:52 AM(UTC)
8 Pages«<34567>»
