Great! Thanks for the response! I will check this.
I have a whirlpool mod# DV945PWPQO that drains very slowly. I removed the hose and let it drain directly into a bucket and it drained slow. I looked at the check valve and all seems well. The dishwasher also will not drain completely.
Originally Posted by: Vegaswingrydr ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a whirlpool mod# DV945PWPQO that drains very slowly. I removed the hose and let it drain directly into a bucket and it drained slow. I looked at the check valve and all seems well. The dishwasher also will not drain completely. The model number you posted does not come up. Verify and repost it. Gene.
Sorry thats a DU945PWPQO.....Can't read my own writing....:rolleyes:
Quote:... I looked at the check valve and all seems well... Have you unscrew it (#15 on the diagram) from the pump? Gene.
Yes, I unplugged the hose, removed the valve and blew some air thru it to make sure it was clear
Originally Posted by: Vegaswingrydr ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Yes, I unplugged the hose, removed the valve and blew some air thru it to make sure it was clear Did you do the same thing with the drain hose? Gene.
No, but I will right now........
I removed the hose and it is clear. I put some water in the dish washer and drained it straight thru the valve and it is still draining very slowly.
