8 Pages«<23456>»
Vegaswingrydr
#31 Posted : Friday, February 26, 2010 4:59:57 PM(UTC)
Vegaswingrydr
There is a clip that holds the flap in the check valve. I removed the clip and the flap and did find a blockage that looked like it was part if the valve before I removed the flap......going to re install and re try
Vegaswingrydr
#32 Posted : Friday, February 26, 2010 5:16:30 PM(UTC)
Vegaswingrydr
still draining slowly
#33 Posted : Friday, February 26, 2010 7:36:20 PM(UTC)
Groups ready for retrieval: Senior Expert, Administrators
Remove the check valve and make sure the hole in the pump plate is clear. See how water will go without the check valve.
resprod
#34 Posted : Sunday, March 21, 2010 9:12:42 AM(UTC)
resprod
Gene:
Is there another way to get to the check valve? I have tried every sort of way to get the wash impeller screw off but it is on tight. I am afraid of damaging the wash impeller as I try to get it off. I have a Whirlpool GU980CGQ3. The unit is 9 years old so I am not going to drop huge money into a fix since I am at the tale end of it's life.
#35 Posted : Monday, March 22, 2010 1:46:14 PM(UTC)
You have to remove the drain hose from the check valve (#15 on the diagram) and unscrew the check valve. There are no other ways to check it. I did not understand why you went to the impeller. It has nothing to do with the drain problem.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU980SCGQ3 | AppliancePartsPros.com
resprod
#36 Posted : Monday, March 22, 2010 3:16:42 PM(UTC)
resprod
Because I was going to from the top as I followed the diagram that the check valve shows it on. It was not until you sent the one with the front door assembly that I realized that it was right behind the access panel :o
Cleaned the valve and did a quick rinse. Drained fine. Thanks Gene!!
#37 Posted : Monday, March 22, 2010 3:32:23 PM(UTC)
jgpetten
#38 Posted : Monday, August 30, 2010 6:14:26 PM(UTC)
jgpetten
Gene:
Does this also apply to Whirlpool dishwasher Model DU945PWPT0? And in your response from above:
The second thing I would check is the check valve (#15 on the pump & motor break down diagram). Remove all water from the dishwasher, remove the bottom panel, disconnect the drain hose from the check valve and unscrew it.
are you saying unscrew the valve?
Thanks,
j
#39 Posted : Monday, August 30, 2010 6:23:04 PM(UTC)
Originally Posted by: jgpetten Go to Quoted Post
Gene:
Thanks,
j
Yes. The clogged check valve is one of the most common cause for slow drain in such pumps.
Here are the breakdown diagrams and Pump and motor parts replacement parts for WHIRLPOOL DU945PWPT0 Undercounter Dishwasher | AppliancePartsPros.com
jgpetten
#40 Posted : Monday, August 30, 2010 7:01:49 PM(UTC)
jgpetten
Thanks for the quick reply Gene! That did it it; just a tiny bedazzle bead from one of my daughter's toys.
thanks again!
j
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
New Whirlpool Dishwasher not draining (Dishwasher Repair)
by Maggy540 12/26/2012 8:55:49 AM(UTC)
Whirlpool Dishwasher not draining entirely (Dishwasher Repair)
by johnwartjr 2/28/2012 6:33:16 AM(UTC)
Whirlpool dishwasher not draining during wash cycle (Dishwasher Repair)
by krausjw 6/5/2011 6:10:04 AM(UTC)
by miketran 1/27/2011 5:50:35 PM(UTC)
by Tubhot2 1/23/2011 9:53:57 AM(UTC)
by Cappsfam 3/21/2010 7:22:43 PM(UTC)
Whirlpool Dishwasher Not Draining (Dishwasher Repair)
by fiorillo 12/8/2009 5:29:52 AM(UTC)
8 Pages«<23456>»
