:) My daughter`s oven every few days has a code of pf and sometimes pf e3. I checked oven senser this morning and ohms showed ok. I replaced Elc about a year ago. What can be going on. I am a diy person not a repairman. Thank you Fred
Hi Fred
The error code "PF" means "power failure". Check the power plug, the power cord and all connections. "E3" can not be together with "PF". In front of "E3" should be "F" with a some number, like "F1" of "F2". Different error codes shows different conditions of the unit.
