Washer started to smell like burning rubber. I pulled the cover to find the belt was burnt in one spot.
I bought a new belt and after about 20 wash loads, the belt was burning again.
I just bought a second new belt and installed it. Now I can smell it burning again. I felt the motor pully and it was very hot. Actually burnt my fingers. I wonder if the pully should be that hot?
Washer works through all cycles. But continues to burn belts. I don't see any broken parts and everything seems to move freely. But you can smell the rubber belt bruning. Every now and then I can hear someting rattling in there somewhere, but I can't tell where it is coming from.
Not sure what to check next. Maybe its time for a new washer?
I bought another spare belt and I am using the washer. It is working, but the belt and pully still gets very hot. I guess if it happens again, I should just buy a new washer. Unless anyone else has any other ideas? I am stumped on this one.
What did you end up doing? I am having the same problem. This is the first time it has happened to me. One belt did break but now it was smoking and rubber smell. I am not for sure what to do. I started to do a test run but it still is giving off the burnt smell. I wish some one knew what to do.
Originally Posted by: bmar ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) What did you end up doing? I am having the same problem. This is the first time it has happened to me. One belt did break but now it was smoking and rubber smell. I am not for sure what to do. I started to do a test run but it still is giving off the burnt smell. I wish some one knew what to do. First thing I did was to buy two belts, so I had a quick spare. Then I sanded down the pullies. They were rough. I smoothed the part of the pully where the belt runs. Its been a few weeks (in a rental house) and so far it is holding and not smoking. Good luck with yours, Tom...
