richrds2
#1 Posted : Tuesday, August 26, 2008 3:03:52 PM(UTC)
richrds2
Washer won't fill with cold water. Hot is fine. If you switch the hoses just the opposite is true. My question is " Should I replace the water inlet valve and if so, can I use a universal one?" Thanks in advance
abadfish66
#2 Posted : Tuesday, August 26, 2008 3:09:58 PM(UTC)
abadfish66
First I would take the hose off the valve and inspect the screen on the valve, and the screens on the hose if any for a clog.
richrds2
#3 Posted : Tuesday, August 26, 2008 5:38:41 PM(UTC)
richrds2
I did that already and water to machine was fine. I suspect either the valve is defective or there is no power to one side. I'm just not sure where to go from here
libertyappl
#4 Posted : Tuesday, August 26, 2008 6:40:53 PM(UTC)
libertyappl
If I may throw in my 2 cents.....it sounds like the valve is out
Nat
GE Dishwasher won't fill after grease (Dishwasher Repair)
by Guest 1/1/2022 3:18:27 PM(UTC)
Washer won't fill on wash cycle only -- GE GTWP2250d0ww (Washer Repair)
Belarus mattmoore 1/4/2019 6:29:50 AM(UTC)
Kenmore washer won't fill won't run motor trips (Washer Repair)
by MEE1963 9/16/2017 10:53:07 AM(UTC)
GE Profile washer won't fill all the way (Washer Repair)
by jimlansing 1/16/2016 4:29:14 PM(UTC)
Help - Maytag Washer Won't Fill On Rinse Cycle (Washer Repair)
by oklanyes 7/25/2015 11:23:28 AM(UTC)
Maytag washer won't fill with full water pressure? (Washer Repair)
by kmwest 6/9/2015 4:39:48 PM(UTC)
Roper washer won't fill on rinse cycle (Washer Repair)
by goff 12/13/2014 12:14:56 PM(UTC)
Washer won't fill with hot or cold water (Washer Repair)
by tinytanic1 12/8/2014 2:44:06 PM(UTC)
Maytag dishwasher won't fill (Dishwasher Repair)
by dkirchner2@wi.rr.com 11/5/2014 5:40:40 AM(UTC)
Whirlpool washer won't fill (Washer Repair)
by Jmccal7 9/9/2014 7:24:00 PM(UTC)
washer won't fill, not inlet valve solenoids. (Washer Repair)
by mikedaddy1472 3/27/2014 12:49:45 PM(UTC)
Kenmore washer won't fill and agitates at beginning of cycle (Washer Repair)
by glockej 12/6/2013 4:44:09 AM(UTC)
Dishwasher won't fill or run (Dishwasher Repair)
by kevin.atkinson 11/28/2013 4:56:56 PM(UTC)
by maxy212 10/2/2013 7:01:34 AM(UTC)
Dishwasher won't fill (Dishwasher Repair)
by mattgumaer 9/18/2013 7:02:29 PM(UTC)
